TheDieselPage.com Forums
The Diesel Page Forums
2020 - TDP's 24th Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Forums > 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance 1992-00 6.5L Turbo Diesel - Welcome to the Internet's first discussion forum for the 6.5L diesel engine. Tips on performance, upgrades, cooling, fuel economy, troubleshooting and more.
Reply
Thread Tools Display Modes
  #1
Old 02-16-2020, 02:11 PM
Lightyear Lightyear is offline
Enthusiast
Default The '99 Burb cranks, smokes, no start
Hello everyone
After sitting for about four weeks since the last stranding episode I stared tinkering with the Burb. She'll crank at starting speed, build about 30 psi oil pressure, almost fire, but not start.
So far, have done the following:
2 new batteries
New Stanadyne gray PMD from Kennedy
Cleaned filter manager
Replaced and bled new GM filter
Checked flow at IP inlet, good fuel no bubbles
Glow seems good, I can watch the voltmeter cycle with the key at on
Attempted start with optical sensor disconnected
Cracked open injector lines 1, 2, 3, 5, 6, and 7...fuel at each of those cylinders. (Can't reach 4 and 8)
It ran until I parked at long term parking for about 8 days, then would crank but not start. It feels closer to starting now, it'll buck and catch for a few seconds but not run, it has gotten to around 500rpm while trying and coughing. Gray smoke at tailpipe.
Any suggestions?
Thanks!
__________________
Buzz
'99 K2500 'Burb, my DD
301K
K&N insert in stock airbox
Relocated PMD behind front bumper
Last edited by Lightyear; 02-16-2020 at 02:12 PM. Reason: forgot to add a statement
  #2
Old 02-17-2020, 09:10 AM
joed joed is offline
Enthusiast
Default Resistor in new FSD?
Does your new gray FSD from Kennedy have a resistor in the connector cavity? My friend just went through this on his 98. His truck would start but run very roughly, like it was missing on more than one cylinder. He installed the resistor from his old FSD, and now it runs great with the gray one. Just a thought. Joe.
__________________
2006 Chevy K2500 LLY Duramax/Allison Crew Cab!
1996 Chevy C2500 6.5 auto Ext. Cab LB
  #3
Old 02-17-2020, 09:48 AM
Enthusiast
Joe -
Yep, I bought a new #5 from JK when I got the PMD. Have been working my way down the troubleshooting guide in the GM manual, will have some updates to the story shortly...
Thanks for the suggestion!
__________________
Buzz
301K
  #4
Old 03-15-2020, 08:53 AM
phantom309 phantom309 is offline
Enthusiast
Things that have caught me before,.
After installing new batteries glow plugs only cycle for a second or two until there has been an attempt to start.
Relay for glow plugs has stuck on an fried glow plugs,.
Stepper motor has given up on the ip and won't give enough timing to start nicely,.
In you case i would pull the 2-3 easy glow plugs on drivers side and use booster cables to verify they are heating up.
Try plugging it in too,. See if it will fire then go from there
__________________
1999 chev suburban C2500
300,000 mi
  #5
Old 03-25-2020, 07:53 PM
Enthusiast
She's alive!! Turns out it was a bad female end on the 4-pin harness from the IP to the PCM. Went back to troubleshooting 101...had glow for sure, air as well, but no fuel. I mucked around with that pigtail connection while cranking and it coughed, almost started. Unplugged, forced the leads a bit further into the connector, re-connected and bang she fired. Found a replacement female end at connectorexpertsdotcom, whom I recommend. There site has a million parts, but of you send photos of either end you need they will match it if they have it. Two FedEx days later I was driving the old beast again.
__________________
Buzz
301K
  #6
Old 03-26-2020, 05:22 PM
JohnC's Avatar
JohnC JohnC is offline
Proud Deplorable
Outstanding!
__________________
"Need" - Wanting to get someone else's money.
"Greed" (formerly meant what "need" means today) - wanting to keep your own.
"Compassion" - a politician's willingness to arrange the transfer.
-Joseph Sobran
Current oil burners: MB 350SDL, Kubota 7510
Gone but not forgotten: '87 F350 7.3, '93 C2500 6.5, '95 K2500 6.5, '06 K2500HD 6.6
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
1992 P30 Chassis Van cranks but will not start JerryOwen 6.2L Diesel - Tech Support - Troubleshooting - Performance 6 04-01-2016 10:35 AM
99 burb stall and no start Judotrip 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance 5 08-18-2015 09:43 AM
No Start - No guages - Cranks Strong jerry598 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance 8 08-18-2005 12:32 PM
CRANKS BUT NO START BERT 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance 7 01-05-2005 08:16 PM
CRANKS BUT NO START BERT 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance 0 11-23-2004 08:39 PM
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2020, vBulletin Solutions Inc.
Copyright 1996-2020 by TheDieselPage.com - All Rights Reserved
