Just returned from a long trip during which I noticed the idiot lights and tach flickered occasionally. Now truck won't start and guages and idiot lights are not working, but engine cranks over strongly. Idiot lights show faintly and guages move slightly when key is turned on after dark. Tested batteries and cleaned cables. LH battery with a bad cell was replaced. Battery cables show continutity and appear OK. All fused checked out OK under hood and at instrument panel and power is present at these locations. I now suspect a faulty ground connection or maybe a faulty ignition switch because the lights and guages have come on 3-4 different times during all the many attempts I've made to fix the problem. When they do come on, the engine starts without any trouble and does not stall out. I also cleaned the ground connection on the RH rear manifold, but did not trace those wires to their source. Can anyone tell me if that connection or what other ground connections could be causing this and where they are located? What else might cause this problem?
Black 95 6.5TD, 929 block, 173k miles, 65k on IP, 48k miles on self-rebuilt engine done in '09, 6 L&S Full-torque inserts in outer main crank holes, Clearwater heads, Fluidamper, rebuilt NV4500, 3" downpipe, 4" exhaust, no cat, dual T-stats, 9 blade fan, spin-on 180 degree clutch, Heath hi-flow water pump and turbomaster, PMD relocated, OPS relay mod, Heath PROM upgrade, and Kennedy headlight harness upgrade soon. Now use semi-syn Lucas 2-cycle oil every fill-up which greatly reduces the frequency of DTC 35-36 codes the PCM/ECM throws.
