The '89-'91, and possibly earlier, gassers had quartz speedometers, for use with the VSS and VSSB modules - the speedo can be grafted into the earlier Rallye gage-pak instrument clusters.
The cluster housings are ABS, easily bonded with common ABS cement from your fav hardware emporium.
I grafted the 5000rpm Rallye tach from an '86 305 Blazer and the quartz speedo from a '91 350 Suburban into my '89 GMC dooley inst cluster when I converted it to EFI 6.5TD.
The '88 electric VSS installed in the T400 fed the VSSB, then to the quartz speedo.
The tach needed a little more consideration, requiring a mosfet circuit tied directly to the Crank Position Sensor input at the PCM.
No failure since incept date of 4\00, tho I did recently convert to 4L80E with dual VSS sensors, including PCM to match - reset the VSSB to compensate, for desired continued accuracy.
jd
