Results 1 to 20 of 22
Thread: Crank no start
    Feb 2014
    NC
    Default Crank no start
    So Friday I had a fishbite and stall episode. Pulled over truck started fine and ran great rest of the day. Saturday truck starts fine, run some errands and proceed to replace water pump and radiator. I had disconnected the positive cables. Got that all done and now the truck won't start.
    New PMD and cable
    Gutted fss
    Have fuel to ffm,out of air bleed,out of drain and to injection pump
    Fuel in clear retun line, moves a little when cranking
    Tried cranking with optical sensor unplugged and cps unplugged, no difference
    Have SES light when cranking. (power to ecm)
    No fuel out injector lines.
    Tried both pmd without extension harness
    Have you ever changed you ignition switch?
    Feb 2014
    NC
    No I haven't.
    My 98 has a bunch of electrical issues that went away after changing the switch.
    Same on my 2004 Topkick.
    Ignition switch is little box on lower steering column not the key cylinder.
    Not on my 98 or 04 they were mounted on the column behind the key tumbler.
    Every GM I have owned had the switch on the top of the column about 6 inches or so down toward the firewall from the key unit.
    There is a rod that connects the sliding switch to the key/lock unit.
    Later ones that use the "chip key" may be different.
    No chip keys on my trucks
    Our 2007 Avalanche has the chip key
    Spendy to get extras made.
    We only got one key with the rig....so had to get an extra.
    The 07 does not have a locking column either....I was surprised at that.
    Dec 2009
    In the North
    When the batteries have been disconnected,. The first start the glow plugs cycle off very quickly.
    Takes at least two tries,...
    1999 chev suburban C2500
    300,000 mi
    Feb 2014
    NC
    PCM was bad.
    1995 K3500 CCLB 6.5 turbo diesel
    Ft. Wayne, In.
    Thanks for reporting back! It's always nice to know how things turned out.
    How old/miles was the PCM?
    Dave
    Dave, N9LOV
    Member #242
    Dave's Diesels:
    '97 2 Dr Tahoe, Intercooled,
    Kennedy ECM, 4" Exhaust
    '02 GMC
    Feb 2014
    NC
    Original as far as I know. 285000 miles
    Dec 2009
    In the North
    Quote Originally Posted by snarl View Post
    I'm a little confused your original post states otherwise,.??
    300,000 mi
    Quote Originally Posted by phantom309 View Post
    PMD. PCM. Meh. Same thing.
    Dec 2009
    In the North
    Quote Originally Posted by snarl;
    New PMD and cable
    You think i'm new here,?
    300,000 mi
    Feb 2014
    NC
    (Ditto)
    snarl (original post):
    New PMD and cable
    PCM was bad.
    DieselDavy:
    snarl:
    phantom309:
    Me:
    Feb 2014
    NC
    PMD- Pump mounted driver
    PCM - Powertrain control module (the computer)
    Is this a southern thing or something?
  1. 02. Crank no start.
    By Flomax in forum Duramax 6600
    Last Post: 12-14-2018, 20:11
  2. 6.5 long cranking time/hard start
    By GreenGiant in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-20-2015, 13:11
  3. engine stalls no wait to start light
    By R.Roy in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-25-2007, 07:37
  4. long start mystery solved
    By sdaver in forum Duramax 6600
    Last Post: 07-18-2003, 09:41
