Thread: 1993 chevy 3500 diesel 6.5 no crank no start
    Jan 2020
    Windsor VT USA
    Angry 1993 chevy 3500 diesel 6.5 no crank no start
    I drove my truck a couple weeks ago parked it now it wont crank and wont start I took out the starter took it to AutoZone they tested it said it was good I put it back in and it still no crank no start I turn the engine manually it turns all the pulleys are turning everything's turning but still no crank no start
    When you say "won't crank" do you mean the starter can't spin the engine? What exactly happens when you turn the key to start? How are the batteries and battery connections? Do the gauges act as expected?
    Dec 2009
    In the North
    Possibly the neutral safety switch is not engaged right? Slamming the shifter into park or trying to start in neutral might work,.?
    Or maybe your starter switch on the steering column had given up,?
    You mention this was 2 weeks ago,.?
    1999 chev suburban C2500
    300,000 mi
  1. 1993 6.5 wont start new injection pump
    By Sb72elcamin350 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 12-31-2019, 20:45
  2. Remove engine/gearbox 1993 6.5 turbo diesel
    By FastFWD in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 04-18-2018, 15:06
  3. Chevy 1995 6.5 N/A Diesel MPG
    By GMDiesel in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-23-2006, 04:43
  4. Bad Starter?
    By fastcat800 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 10-24-2005, 17:27
  5. 3500 miles on diesel for oil
    By gardnerteam in forum Duramax 6600
    Last Post: 05-28-2004, 19:20
