Results 1 to 12 of 12
Thread: What detroit diesel am i messing with!?
    Apr 2013
    Oregon
    Default What detroit diesel am i messing with!?
    ok i bought this old diesel genset as a...project i guess, something to mess with. thusfar i can't get it to fire up fully, had it trying a bit on ether, and when i pull the fuel rod all the way out it smokes like crazy but...thusfar, haven't made it really go Vroom...
    the dataplate says model 3913 but...i can't find anything online in regards to a detroit 3913...
    Dec 2000
    Hawaii/Arizona
    It looks like 3-53 series. That is three cylinders and 53 cubic inches per cyl. Look at the valve cover if it is held on with screws it is a 53 series if it is secured with two large wing nuts it it a 71 series. They are two stroke and loud but they will run forever.
    John
    *2007 Pontiac Solstice.
    Apr 2013
    Oregon
    thanks, it has 2 large wing nuts you can undo by hand on the valve cover so i guess it's a 3-71
    Sep 2005
    Washington, DC
    Looking at the air box covers, I'd say you have a 3-71.
    2015 VW Passat TDI SE, 6 speed manual
    Past Diesels
    1980 MB 240D, 4 speed manual
    1983 GMC Vandura 3500 Nu-Wa 23' Class C Motorhome
    6.2L Diesel, Turbo 400
    1985 MB 300D Turbodiesel, auto
    1992 Chevy C2500HD 6.5 Dieselturbo, auto
    1994 Chevy C2500HD 6.5 Dieselturbo, auto
    2010 VW Jetta Sportwagon TDI, 6 speed manual, sunroof
    Apr 2013
    Oregon
    thanks guys, still haven't gotten it fired up... like i said, when i pull the fuel rod out it'll smoke enough to...kill all insects within a 15ft radius, but beyond that doesn't even sound like it's trying, thinking i should get some fresh diesel... if that doesn't do it, perhaps a sticking injector? i did pull the valve cover (it is EXTREMELY CLEAN) and everything is free, nothing is stuck, i'm amazed by how clean it it... i made sure all the lines were tight to the injectors.
    Dec 2000
    Hawaii/Arizona
    Oregondiesele,
    There is a emergency shut off on Detroit Diesel engines. It is spring loaded and will snap shut and shut off the air supply. That is something that is easy to miss if you are not familiar with DDs. Also fresh fuel and fuel filters are a good starting place.
    Good Luck
    John
    Looks more like that silver solinoid to the left of the blower is attached to the shutoff flap. Is it moving when power is appied?
    Apr 2013
    Oregon
    it doesn't move, it is stuck in the Down position, i've tried it in both the up and down positions with no luck (either way it just smokes up the yard)
    Nov 2008
    So. Cal. USA
    The silver solenoid attached to the blower inlet housing is an emergency air shut off. Make sure the little reset lever on the bottom of the trip is down. That will let air to the blower. Make sure you prime the fuel system good. You should have fuel coming out the return line from the head. Disconnect the fuel line at the output of the fuel pump and prime it there. It should start. Diesels don't like air in the fuel system. You might also want to check valve clearance and injector timing later. Have fun.
    Apr 2013
    Oregon
    i did a no-no today, and ran it on some ether, it fired right up, and just needed a trickle at low rpm's, and ran on it's own at higher rpm's but smokes like a mother....
    Dec 2000
    Hawaii/Arizona
    Oregondiesels,
    Throw the ether can away and spray WD-40 into the motor. The WD-40 can't hurt the motor and is almost as good as ether. The DDs will smoke a lot when they are cold, so the smoke may not be too bad of a sign. Did you get fresh fuel and fuel filters? They are the first step to get your DD running. The second step is to make sure the emergency shut off is open. That motor will run if it has air and fuel. If it has a primer pump, pump it when you are trying to start the DD.
    If you want to get a good idea of the condition of the motor, remove the three air box covers. They are the three covers on the side of the motor, one bolt per cover. You will be able to take a good look at the pistons and rings. If there are pieces of rings in the air box you will need to buy some liner kits and rebuild the motor. If there are not pieces in the air box you just have a fuel and air issue.
    Good Luck
    John
    Nov 2008
    So. Cal. USA
    Quote Originally Posted by oregondiesels View Post
    Ether won't hurt a detroit 2 cycle engine. Check the air filter and make sure it isn't plugged.
