Issue with the go fuse
I just lost my glow plugs yesterday so I did the standard replacement of the controller..... still don’t work..... I checked the fusible links and they’re fine…… Then I checked the fuses in the engine compartment and found out that the glow plug fuse has no power going to it whatsoever. Did some checking and someone had said if the light is out in the Dash then it wouldn’t work so I checked the light in the Dash it’s fine. Any help With this fuse not lighting up in the control box in the engine compartment would be a huge help considering the truck is now stranded at work and I’m trying to get this done. Just in case this is a 1996 GMC suburban with the 6.5 diesel
1986 K5 Blazer (Restoration in progress): stage II racing "K" transmission with +4 quart pan, Banks turbo, new GP’s, 3rd rebuilt IP, Rebuilt injectors, Stud Grille, Aluminum Radiator, Halogen light upgrade, fog lights, and added factory Cruise and rear power window
1996 GMC Suburban K2500 6.5l diesel (Restoration in progress). Running on a DB2 IP, new GP’s, rebuilt injectors, rebuilt transmission with +4 quart pan, dibble din GPS radio, USB and 12v charging in the door pullers, Chasing down the wire gremlins at the moment.......
I think I’m a glutton for punishment
