The Diesel Page Forums
2019 - TDP's 23rd Anniversary
  #21
Old 12-04-2009, 10:05 PM
mastertech mastertech is offline
Default gas in fuel system
a little fyi they will not void the warranty. here is the trick that the dealer uses i know i work for one.
step1 drain the fuel out useing a hose siphon out as much as you can try to get the fuel guage to read E. change the fuel filter add stanidyne diesel conditioner to the fuel tank and add diesel to system 5 gallons. prime the system and then start let it idle for 10 min and then get it to a fueling station and fill it up again this time with diesel . it should be ok. if it is chattering or has no power then you may have a problem. but make sure that you get out as much as you can. make sure that you have some cans to put the contaminated fuel in then you have some fuel for you lawn mower
  #22
Old 02-03-2010, 12:51 AM
havenopower havenopower is offline
.Newbie.
so running gas on accident in a dmax, and it wont blow up right a way wow
  #23
Old 03-19-2010, 03:18 PM
richp richp is offline
Default Lmm
Hi,
Just a word that the 25% dilution threshold may not apply to LMM engines.
FWIW.
Rich Phillips
Member #27
2019 K-2500 Crew Cab Z71
Cedar Creek Silverback 33RL Fifth Wheel
In The Past: '82 6.2 Jimmy Blazer, '93 6.5 GMC K-2500, '01 DMAX K-2500, '09 DMAX K-2500
  #24
Old 05-30-2013, 09:57 PM
ceide4489 ceide4489 is offline
Newbie
My dealer says the trucks are designed to downrate the power enough and shut down prior to any damage being done and you should be OK
  #25
Old 06-03-2013, 05:54 PM
gimpyhauler's Avatar
gimpyhauler gimpyhauler is offline
Dmax,
Very nice having you around. Thanks.
Eddie
2007 GMC Sierra Classic 2500HD CC/LB (LBZ)
211,000 miles / DVD player
Kennedy Diesel Tuned Computer
Manually extended towing mirrors
Winter Grill Cover/screen
Tough Country front bumper
12,000# Warn Winch
KC Fog Lights
KC 130w Driving Lights
Bradford Built Flatbed
Firestone Ride-Rite Air Bags
More things covered by crochet than I'll admit.
  #26
Old 06-03-2013, 07:50 PM
DmaxMaverick's Avatar
Administrator
Quote:
Originally Posted by gimpyhauler View Post
Dmax,
You're welcome, alway.
Was there a reason you're in THIS thread? Not sayin'?
  #27
Old 10-06-2014, 12:05 AM
pascuzzo pascuzzo is offline
Newbie
Default Just takes some work to correct.
2006 Chevy Silverado 2500HD, Allison, Duarmax 6.6L:
Put 24 gals of gas into the tank that still had about 1.5 gals of diesel remaining.
Drove 9 miles. Other that a slight increase in diesel noise everything seemed OK. Parked it and shut it down.
Returned to truck 2 hours later, would not restart. Tried 3 times, then flashed back to image of the pump and realized I grabbed the wrong nozzle.
Smelling the filler spout confirmed the error. Embarrassing tow truck ride home.
Fixed it by:
Used a siphon pump and several gas containers to empty tank.
Replaced fuel filter.
Added 5 gals diesel.
When priming filter, I kept pumping until only diesel came out the bleeder port.
Caught overflow in a drain pan.
Ready to try starting. Figured I'd give it 3 tries for 10 secs each.
First and second tries did nothing but crank the engine and further purge the fuel lines.
On the third try it fired up, ran erratic for about 10 secs, then smoothed right out.
Drove to gas station filled it with diesel and normal engine sounds and exhaust smell returned. All seems to be fine now.
Phew!
My gardener just scored 25 gals of free lawnmower gas with a little diesel fuel additive.
  #28
Old 02-18-2015, 12:03 PM
pippin pippin is offline
Newbie
A couple years ago I put gas in my diesel engine, it sat for a week or so, it now cranks and runs after I drained the tank and lines but only when you prime the filter, once you quit priming it quits running. What could this be
  #29
Old 02-18-2015, 01:05 PM
AKMark AKMark is offline
Building another 6.2L powered vehicle
You could have a leak in the filter housing, allowing air in which shuts it down.
  #30
Old 02-18-2015, 01:31 PM
More Power's Avatar
Administrator
Fixed it by:
Phew!
You did good! That's basically what I would recommend anyone do for a situation like yours.
Like what you mentioned, the fuel mixture can be and should be used. It's too expensive to waste. Just use it in an engine that isn't too picky - like a lawn mower. If the mixture is mostly diesel, I'd only use 10-20% of the gas/diesel mix per lawn mower tank and the balance straight pump gas. Jim
Copyright ©2000 - 2019, vBulletin Solutions Inc.
