The Diesel Page Forums
2019 - TDP's 23rd Anniversary
  #61
Old 06-24-2008, 05:21 PM
AKMark AKMark is offline
Building another 6.2L powered vehicle
Those tires are pretty heavy, that makes a bigger difference than most realize. Also, how far off is your speedo now? Make sure to take that into consideration.
  #62
Old 06-25-2008, 05:49 AM
leolkfrm leolkfrm is offline
The lift kit won't affect as much as the tire size, With 373 rears and adding bigger tires the allision computer starts changing things, sensing the load from the tires it adjusts to more of a tow mode, changes the shift points and converter lockup.
I know of a truck with 22.5's that won't go into full over drive lockup untill 25mph because of the matchup of tire to rear end.
As always it takes a diesel a long while to break in compared to gas. It took about 17000 mi to notice a dif in my cat330
  #63
Old 06-25-2008, 12:07 PM
Ric Ric is offline
Quote:
Originally Posted by craigth View Post
If I were to do it over again, and especially with the $2.99 for 3yr gas purchase promotion, I would check out a Dodge Cummins.
I agree that in my case the speedo and odometer are probably not accurate due to the larger wheels but. hand calculating nets the same piss poor 10-11MPG. Larger tires should NOT make that much difference in MPG vs stock tires! With the Duramax I should be getting at least 13-15 if not higher considering some on this forum claim 17-20, which sorry, I don't believe!
I did find cool product that I would like to try. It's a solenoid operated exhaust bypass. I think the gas mileage issue in these Duramax's is partially related to all the smog crap they put on in the exhaust. Check out http://www.streetpro.us/PowerMasterPics.html
I really don't know. I think if your tires are 10% larger than stock diameter, that affects the circumference greatly (10%) and hand calculating cannot make up for that. Let alone the electronic thinking the ECM and allison are doing for you.
For instance, the DIC on my 6.0 1500HD 4x4 reads "average" 10 to 11mpg if I let it figure over 3-4 tankfuls of normal home and business driving.. My tires are 305/70/16 Wranglers and I guess they are about 10% larger than the toy tires which came stock on the HD.
I cannot speak for the innacuracies of the DIC regarding gallons used because I doubt any of us know for sure we get an exact gallon at EVERY pump or not, so that's another variable.
I do agree that I expect more than 10-12 mpg or I'll just keep my 6.0HD.........
  #64
Old 07-18-2008, 03:52 PM
vsp114 vsp114 is offline
Newbie
2008 2500 HD crew cab, long box bought in March, don't drive it much yet, but with about 5,000 miles, getting between 17.54 to 18.81 hand calculated. Mixed driving.
  #65
Old 08-22-2008, 07:08 PM
mesam57 mesam57 is offline
Newbie
Default 2008 2500 HD 4x4
Just took delivery. 1 tank so far. Dash shows 14 - 16 in city. Highway driving can be good or bad; Seems the truck likes to run about 68 - 70 mph and 1800 rpm's. Running here the dash shows 22.6 mpg. Push the speed above 70 and 2100 - 2200 rpms and the mpg drops to 17 - 18 mpg.
I read about the priogrammers and the results don't seem to justify the cost.
I here (rumor) that the 2008's have a tattle tale in the on board computer. Do theses things void the warranty?
  #66
Old 09-02-2008, 04:18 PM
Ric Ric is offline
Well I bought the 08 Crew Cab short bed 4x4 chivvy with Duramax
Riding home the DIC calculated 22mpg with 1hr of freeway only driving... round town averaging with that freeway run over the next couple of days, the DIC is calculating 14 to 15mpg... Dunno bout the accuracy til I do some hand calculating to check GPS speed to the truck speedo and then hand calculate MPG...
I need to study this site more to find out about all the programmers etc because I do intend to run 305 70-17's on this truck
By the way, what is with the cooler thingy for the fuel being down near the ground in front of the fuel tank with no protective skid plate?
  #67
Old 09-03-2008, 11:14 AM
Sivrug2 Sivrug2 is offline
Newbie
There is a tattle tail feature on the LMM's that keeps track of the programming/flashes. This was relayed to me by the shop foreman and friend at the local GMC dealer.
I recently did a turbo back exhaust and installed a "Spare" computer that was programmed mild upgrade/tow.
Hand calculated my mileage in town is up 1-2MPG on the highway 5-7 MPG increase.
  #68
Old 09-05-2008, 08:38 AM
Ric Ric is offline
will the tattle tale feature void my warranty if I install one of these programmers ?
  #69
Old 11-03-2008, 09:42 PM
SlimWallet SlimWallet is offline
Newbie
Default Mileage
New 2008 GMC 2500 DC Crew cab....Colorado
First tank....mt, mixed town and highway.....16.2 mpg
Second tank.....mt... up the mountains to go fishing...mostly highway and 70 mph.....17.4 mpg
Hand calc'd
Slim
2008 DMAX, 4wd, LB, CC
SRW, 265/70/17
  #70
Old 11-04-2008, 08:34 AM
Duramaster's Avatar
GMC World Class Technician
The ECM is supposed to keep track of the last 10 program reflashes.
