The Diesel Page Forums
2019 - TDP's 23rd Anniversary
  #11
Old 08-25-2009, 01:06 PM
dr.olds dr.olds is offline
Hot Rodder
Cool
does any body have a part# for a filtration kit for an LB7? would put one on if had a #!
  #12
Old 08-25-2009, 02:00 PM
DmaxMaverick's Avatar
Administrator
Quote:
You don't need a part #. You have several options HERE. John Kennedy and Greg Landuyt (both are TDP members/supporters) offer the best there is to be had. The problem is choosing.
  #13
Old 08-25-2009, 03:10 PM
chipper chipper is offline
Thumbs up
[QUOTE=richp;247126]Hi Gang,
1. Year/Make/Model truck - 2001 K-2500 Chevy Standard Cab
2001 GMC EXT CAB
2. Engine code (LB7, LLY, LBZ, LMM) - LB7
LB7
3. Type of additional filtration added, and at what odometer reading - Universal Kit/150k
CAT750 post OEM 38K
4. History of injector replacement, if any, and at what odometer reading(s) 1 set at 90k, second set at 165k
Origional
5. Overall satisfaction with additional filtration - return on investment commentary - too soon to know, since I was (yes, I'm very ashamed of myself here) tardy in getting the extra filtration on with the early sets of injectors. Have to say it gives me a lot more confidence for the future, though.
Looks good so far
chipper 2001 GMC,,D/MAX,SLE,EXT CAB,LONGBED,LINEX,FIRESTONE AIR BAGS,,driv\'en it & smilling, 32' Excel 5er
  #14
Old 08-25-2009, 03:47 PM
bigchev's Avatar
bigchev bigchev is offline
1. My truck is a 2003 Ext. Cab. with a lot of aftermarket performance equipment, turbo,intake,4" exhaust, Industrial Injection dual fuel lines, lift pump,exhaust brake, built tranny and triple disk convertor, KENNEDY 100/250HP ECM and more.
2. Engine is LB7
3. Additional filter/water seperator is a heated racor 2 micron.
4. Still running stock injectors. I have used AmSoil Diesel Fuel additive for approx. 3 years along with AmSoil Cetane Booster.
5. I am satisfied with the Racor filter which was installed at 30K. I am now at 41K. I will change both stock and Racor filter this coming spring. Previously to installing the Racor add on filter I was changing the stock filter every 5K miles.
Since my truck has low miles I suppose that it is still too early in it's life cycle to need injectors. At the rate I drive the truck 6500 annual average I hope that any future injector failure will be was off in the future.
'03 Chev Duramax ext. cab, Kennedy ECM,After Market turbo,tranny, triple disk convertor, Exhaust Brake, electric tran. cooler, dual exhaust, Supertank 57 gallon.
  #15
Old 09-24-2009, 09:49 PM
Heartbeat Hauler's Avatar
Heartbeat Hauler Heartbeat Hauler is offline
2001 Chevy 3500 dually
LB7
Racor R60S pre-OEM from Greg @ approx 15000 miles.
60K+ miles still running original injectors.
I'm happy since I haven't had to replace injectors yet, and I should note that I have been using additives since day-one (started with Power Service now using Stanadyne). I don't have that many miles on it yet, but with all the travel back and forth to W.Va. (We're moving back home) that low mileage is gonna change.
JP
Jeff
1996 Caprice 5.7L LT1, B4U Suspension, KYB shocks & Hotchkis sway bars, BMR RCA
  #16
Old 10-30-2009, 07:33 PM
crafty's Avatar
crafty crafty is offline
2001 GMC EXT CAB 2500 HD
LB7
None Added
182,000 KMS and the 2,4, and 6 injectors are still original injectors. The other 5 were done one at a time starting in 2002. The last one was changed 22 months ago. I've had no troubles since then. I use Stanadyne every tank full and I think it helps alot. The truck was built in Nov. of 2000 and went on the road Dec. 21, 2000. I am consistantly getting 21.5 mpg highway and 16 mpg towing the trailer (imperial gallons) .
2001 GMC 2500HD Ext cab SB Dmax 6 speed
86 6.2D
79 5.7D
D.P. member # 1885
Ontario Plate "DMAX DSL"
  #17
Old 11-01-2009, 01:43 PM
et et is offline
1. 2002 Chev 2500HD ECLB 4X4 purchased new in November of 2001.
2. LB7
3. Purchased Cat base and Cat 1R-029 filter in July of 2003 but horror of horrors did not install until June of 2007 at 69,151 miles and 2,024 hours. Currently have 91,704 miles and 2,655 hours. I use Kennedy’s fuel pressure gauge to determine when to change filters. So far, Cat filter needs to be changed at about 300 hours. Wix 33910 filters in OEM location looked new. I cut open the filters when removed. As soon as I get home, I will check fuel pressure again and change just the Cat filter and recheck the fuel pressure to determine if the OEM filter needs to be changed. When I exhaust my current supply of Wix 33910 filters, I will change to the new OEM filter. I try to never let my 56 gallon fuel tank get below half full.
4. Still have original injectors.
2002 2500HD ExtCab LB 4X4 LT D/A
  #18
Old 12-18-2009, 07:17 AM
WyoDutch's Avatar
WyoDutch WyoDutch is offline
2009 1-ton extended cab.
Don't plan on doing anything except add lubricity agent to the fuel and regular OEM filter changes.
I fuel from my bulk tank, and logic dictates that if I were put a high-efficiency filter anywhere... it would be at the pump. At least that's my thinking.
2009 GMC SLT 3500 Xtended Cab 6.6L
Lubricated By Rotella T-6 and Amsoil EAO52 Filter
  #19
Old 12-24-2009, 12:27 AM
GordonMarks GordonMarks is offline
The Suburban:
Changed injectors, presumably because it had been sitting for a while in our DRY weather. Engine has a little less than 100K by what I can tell from dealer info & extrapolating the tag info before it was wrecked.
Stock filter(DELCO only),& I added an old Raccor 500 10 micron (I think)like we used on the 5.7L & 6.2L(BOY, that was FUN!!!) I don't have the room that the later ones have. Nothing in it after 5K. It's before the main filter. I try to buy fuel where I think they will have a high turnover.
Gordon Marks
Tampa, FL
99 Suburban C2500 W/LB7
64 Biscayne 409 NSS
10.81@124.65 3920lbs.
  #20
Old 12-24-2009, 06:41 AM
conway conway is offline
See below for filtration installed (installed within 10,000 miles of new in both cases). I just had someone check my injectors with a TECH 2 on the 03 since the 7 year warranty is expiring. The check showed that the injectors (return rate, etc.) are right on the money.
1) '03 GMC 2500HD Dmax/Ali Ext/Short 4x4; 4" exhaust, egt and boost gauges; exhaust brake; Bilsteins; BD exhaust manifold; Oil Guard bypass; Lubrication pre oem fuel filter; Tekonsha Prodigy; Mag-Hytec differential cover; Suncoast V transmission w/deep oil sump
2) '07 Classic GMC 2500HD Dmax/Ali Ext/Short 4x4'; Bilsteins, Silastic shackles, BD exhaust manifold; Oil Guard bypass; Lubrication pre oem fuel filter; Tekonsha Prodigy; Federico sway bars; Dipricol boost and egt gauges; Transgo Jr,, Mag-Hytec differential and transmission pan
