The Diesel Page Forums
2019 - TDP's 23rd Anniversary
Go Back   TheDieselPage.com Forums > Other Diesel & Truck Related Forums > GM Medium-Duty
GM Medium-Duty Learn more about GM's new medium-duty trucks and diesel engines.
Old 10-15-2012, 02:54 PM
cowboywildbill's Avatar
cowboywildbill cowboywildbill is offline
Moderator
Default No low beam headlights 2008 Kodiak 4500
No low beams. Replaced both low beam bulbs. Have all bulbs lit on high beam selection. Have daytime running lights. But when you select low beams only just have the marker/tail lights and no head lamps. I also checked all fuses. aAnd the DRL relay is OK. I'm thinking the high low selector switch is bad? And not the main headlamp switch? Any Techs please chime in. Thanks
0000000
Old 10-15-2012, 09:34 PM
Inspector's Avatar
Inspector Inspector is offline
Moderator
Wink
The low beam lights work through a relay that is located in a panel in the pass side dash below the air bag. There are two captured #10 bolts in the bottom edge of the panel. There is a fuse and relay location ilistration inside of the panel.
Denny
2006 Jayco Seneca 35GS, C5500 chassis, DA 6 SPd, 360hp,
LBZ, Bilsteins Edge with Attitude level 3. True 4" turbo back, high flow muffler. Super springs and Firestone airbags
Member # 128.
Old 10-17-2012, 02:59 PM
Moderator
Thanks Denny, I checked those fuses. I think the relay is the DRL. Any other relays or idea's. Thanks
0000000
Old 10-17-2012, 07:24 PM
Inspector's Avatar
Moderator
Do you have DLRs? Chances are you don't. If you don't change the DLR relay if your fuses are good and you should get both lows and DLRs. Let us know.
Denny
Member # 128.
  #5
Old 10-18-2012, 06:51 AM
Inspector's Avatar
Moderator
Further make sure that your parking brake is fully off for the DLRs to come on.
Denny
Member # 128.
  #6
Old 10-18-2012, 03:31 PM
greatwhite greatwhite is offline
I seem to remember reading several posts about a wiring harness on the fender well chaffing on some kodiak models and weird lighting issues.
Might be worth a poke around the engine bay to look.....
1998 k2500
  #7
Old 10-19-2012, 12:02 PM
Moderator
Angry
Thanks I'll check the harness out. I do have DLR's and I did make sure the Ebrake is off. I just don't have the low beams. It's wierd. I think maybe it's the high low switch in turn signal lever. I guess I have to pull the wheel and r&r it. Thanks
0000000
  #8
Old 10-19-2012, 09:14 PM
Inspector's Avatar
Moderator
Question
I've looked at the wiring diagram and what I see is that if you have DLRs you are getting power to the low beams. The low beams get there power through the DLR relay. It almost has to be a bad relay.
Denny
Member # 128.
  #9
Old 10-20-2012, 08:56 AM
Moderator
Ok, I had swapped out the reverse relay with the DRL relay. They both use the same relay. I wonder if they could both be bad?
0000000
  #10
Old 10-20-2012, 09:28 AM
Inspector's Avatar
Moderator
Question
Not likely. Back in the diagrams I go.
Denny
Member # 128.
