What tuners do you recommend for the 6.5
What year are you working on? 94/95 take a chip not a tuner.
-Patrick Henry
A5150nut
2006 K3500 D/A
94 6.5 4x4 5spd Sold
1999 k3500
I have a 1995, so I have the "chip". I used Kennedy Diesel. I would recommend him for all 6.5L products. For your application, you will need to swap the entire ECM for an upgrade:
http://www.kennedydiesel.com/categor...bCategory2=164
have anyone got a heath diesel ecm or ss diesel supply tune ecm i heard mix reviews on heath tune ecm
I have a Heath Tune in a 95 GMC K3500 6.5 truck.
This tune is one he did back several years.
I was pleased with the performance and overall function.
Heath sold out so I can't say anything about any of the new stuff.
Thanks for the info
