TheDieselPage.com Forums
The Diesel Page Forums
2020 - TDP's 24th Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Forums > 6.2L Diesel - Tech Support - Troubleshooting - Performance
6.2L Diesel - Tech Support - Troubleshooting - Performance 1982-93 6.2L Diesel - Welcome to the Internet's first discussion forum for the 6.2L engine.
Reply
Thread Tools Display Modes
  #81
Old 10-18-2020, 04:07 PM
2INSANE's Avatar
2INSANE 2INSANE is online now
Enthusiast
Just got the books in the mail! Great and thick too! I wish I had these 10 years ago! Thank you!
  #82
Old 10-18-2020, 06:04 PM
2INSANE's Avatar
Enthusiast
Right now, I am waiting for the experimental water pump to show up. While I am waiting, I decided today to go back to the Fuel Injection Pump woes...
First off, after more research I come to find from The Diesel Page books the badger diesels injection pump I bought was actually for a 92 6.2 diesel. It was tuned and calibrated for the 92. The posting was for all 6.2 diesels but learning now that not all 6.2 injection pumps are the same. There are certain pumps made for certain years and model motor. Badger diesel should have known better before selling their pumps as an all general use.
Awe well... So looking at the original J code injection pump that came with this motor, low miles, but weather worn because there was no hood on the donor.
I was able to remove the bolt that corroded and broke. I used my torch to heat up the aluminum to help separate the threads from heat expansion. Since I have many spare injection pumps, I pulled the oldest and crappest one out of one of my 6.2 spare part boxes.
Taking off the good parts I needed, I then took off the cap on the good injection pump, throttle position sensor, rocker arm and throttle shaft.
The goal is to replace the old rubber O-rings on the throttle shaft to prevent the very common fuel leak from that area, replace the broken bolt and lever. But darn it! The parts store is closed! Lol!
more pics on next post...
  #83
Old 10-18-2020, 06:05 PM
2INSANE's Avatar
Enthusiast
Pics continued...
  #84
Old Yesterday, 09:47 AM
Yukon6.2 Yukon6.2 is offline
Enthusiast
Quote:
Originally Posted by 2INSANE View Post
Also the reason why I wear a full respirator is because there is a lot of harmful chemicals I am dealing with.
Aluminum Oxide
Brake Cleaner fumes
Rtv fumes
Asbestos from old gaskets
Dirt
Rust
Spray paint fumes
Copper Spray fumes
Diesel Fuel fumes is harmful as well
I imagine coolant fumes is bad too
Fibers in the air from the Grinder disks
A full respirator with organic filters are a MUST HAVE! It’s about time to replace my filters. I strongly encourage anyone doing this kind of work on their motor to wear one!
Good to see you concerned about your health...
You should see if you can convince your helper to quit smoking,there has been a lot of butt's in your pictures
__________________
  #85
Old Yesterday, 05:44 PM
2INSANE's Avatar
Enthusiast
Well I’m glad you are not commenting about how bad of a job I am doing on the motor! Lol! I’ve been telling myself to quit smoking for 21 years now. I got the coronavirus this February and it was horrible! I figure I might as well try to prevent further damage with the respirator. Maybe I’ll live longer then my father whom died at age 53 from brain cancer because of the 30 years as a painter and breathing fumes that whole time. He was not a smoker. My grandma who smoked 3 packs a day lived to 80 years of age. All things in moderation I guess... Cell phones, microwaves, radio waves, TVs, plastics, stick free pans, Pick your poison...
  #86
Old Yesterday, 06:25 PM
2INSANE's Avatar
Enthusiast
Since we are in this topic, I changed my filters today and cleaned my mask. Check out how bad they got in a short time period!
  #87
Old Yesterday, 06:34 PM
2INSANE's Avatar
Enthusiast
I finished doing the throttle shaft O-Rings and put the injection pump back together.
Cleaned up the injection pump mounting locations with brake cleaner and a paper towel. Got the new injection pump gasket on.
I installed the ip and refurbished the 3 gear bolts, added blue lock tight and torqued to 20 foot pounds
  #88
Old Yesterday, 06:42 PM
2INSANE's Avatar
Enthusiast
Then installed the three nuts mounting the ip to the timing plate and made sure the 2 timing marks are perfect.
Then I cleaned up the rear coolant plate covers with a razor blade, wire wheel and brake cleaner. Then refurbished the bolts and reinstalled the plates with the bolts in their correct locations. Making sure the longer grounding bolt has a very generous amount of lock tight on it.
I don’t like to waste and spend much money if I can. I squeezed every last bit of rtv from the tube that had hardened on the end and got the job done!
  #89
Old Yesterday, 06:47 PM
2INSANE's Avatar
Enthusiast
Here are some torque specifications for most all 6.2 diesels. I had found this years ago and kept it in my records. Hope this helps.
6.2 torque specs
ALL in ft lbs unless otherwise mentioned.
Bellhousing - 30
Cam Gear - 75
Cam Thrush Plate - 17
Connecting Rod nuts - 48
Crankshaft Pulley - 30
Cylinder Head (3 steps) 20 / 50 / +90 degrees
Engine Mount to Block - 75
Engine Mount to Frame - 50
Exhaust Manifold - 26
Flywheel bolts - 65
Front cover bolts - 33
Glow Plugs - 156 in/pd use anti-seize
Harmonic Balancer - 200
Injector Lines - 19
Injector Nozzle - 50
Injector pump Retaining nut - 30
Injector Pump Gear bolt - 20
Injector Pump Baffle bolt - 33
Intake Manifold - 31
Lifter Guideplate - 18
Main Bearing caps inner 110 / outer 100
Oil Cooler Line to Filter - 12
Oil Cooler to Rad -25
Oil Pump Drive bolt - 31
Oil Pump Retaining bolt - 65
Oil Pan Plug - 20
Pressure plate to flywheel bolts 38-40 ft-lbs (use loc-tite)
Pulley to Damper - 20
Rocker Arm Cover - 16
Rocker Arm Shaft - 40
Starter Bolts - 35
Thermostat Housing - 35
Turbocharger to Manifold - 37
Vibration Damper - 200
Water Crossover to Head - 31
Water Pump to Cover - 31
Water Pump Plate to Pump - 16
Vacuum Pump Retaining nut - 31
Valve Covers - 16
Oil Pan bolts - inch lbs
rear 2, 84
others 204
Body Mounts - Bolts - 55, Nuts 35
  #90
Old Yesterday, 07:06 PM
2INSANE's Avatar
Enthusiast
I really want the dual thermostat coolant cross over. I did a mock up and it’s hitting the throttle cable plate. I am going to tackle this problem and will post lots of pictures for you all since it is not a common upgrade for the 6.2.
  #91
Old Today, 06:30 AM
a5150nut's Avatar
a5150nut a5150nut is online now
Enthusiast
I believe there was an article or several posts about mods needed to get the duel thermostats to work with the mechanical linkage. Might try a search for that.
__________________
-Patrick Henry
A5150nut
2006 K3500 D/A
94 6.5 4x4 5spd Sold
  #92
Old Today, 09:08 AM
Enthusiast
You are showing a lot of pic's and doing a good job on the motor so that is great
I was a pack a day smoker since i was a teen,i quite once my daughter was born.I didn't want to be a bad influence on her.I quit drinking around the same time.I decided that it didn't make sense to pay some faceless company good money to slowly kill me.
Plus our daughter is a bright girl and we managed to put away enough money for her to have a University education of her choice.A lot of hard decisions were made over 20 years but worth it. She is in her 3rd year and has been averaging A- grades.I am so proud of her for choosing a path and excelling in it.
Unfortunately for me she chose sides in the divorce and i haven't heard from her in 17 months.
But i live in hope that one day i will get a call that starts"Dad... "
__________________
  #93
Old Today, 09:13 AM
Enthusiast
Want a picture of what i did for the throttle and dual t stat setup?
You will have to cut the outlet housing and have it re welded to make it work.
I did a mechanical conversion on a 98 and had to build a special throttle plate/holder on that one too,but the outlet housing didn't get altered on the 98.
__________________
  #94
Old Today, 06:31 PM
2INSANE's Avatar
Enthusiast
Sorry to hear about your daughter... I have some crappy story’s too we can talk about over a beer or coffee!
Yes please share!
  #95
Old Today, 06:32 PM
2INSANE's Avatar
Enthusiast
Quote:
I found a couple but pictures and info are limited.
  #96
Old Today, 06:34 PM
2INSANE's Avatar
Enthusiast
So, today I am taking a few steps back. I decided to remove the injection pump and timing plate because when I removed the water pump plate, there is a chance that I disturbed the timing plate gasket which would cause a coolant leak.
I am glad I removed the timing plate because I can see that an oil leak started from the lower part of the pan and timing cover. Also the crank shaft timing plate seal was leaking as well.
I will refurbish the nuts and bolts this weekend and clean off all the gaskets. My goal is reinstall everything in the same day before the RTV cure time expires. Plus I am waiting on the water pump to arrive which gives me time to go threw all the little things. I will tap and clean all the bolt holes as well.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
85 6.2 w/banks turbo to 94 6.5 turbo fatboy6949 6.2L Diesel - Tech Support - Troubleshooting - Performance 1 01-23-2014 11:58 PM
Will a factory 6.5 turbo system work on an 80's 6.2? More Power 6.2L/6.5L Diesel - Upgrades & Service Questions Answered 18 11-12-2013 12:10 PM
Banks kit on high milage 6.2? darkroad 6.2L Diesel - Tech Support - Troubleshooting - Performance 2 06-01-2006 01:08 AM
How to turn down Injection Pump off engine, & TURBO ?'s john8662 6.2L Diesel - Tech Support - Troubleshooting - Performance 3 11-13-2003 10:10 PM
