Results 1 to 2 of 2
Thread: M1009 Gen1 light
    Default M1009 Gen1 light
    Hi, new to the board, just bought an M1009 w/ 38k miles and drove 100 miles home . While it was a blast, I did notice that the Gen 1 light will come on when I use a flasher, wipers, brake lights etc. If I goose the accelerator it goes out. I have been told maybe it could be the Battery cables. The other thing is that once in a while when I start the truck I get a clunk and it won't start. If I let it sit and try again, it kicks over. This is a brand new starter. Any thoughts?I
    Sep 2006
    Anchorage, Ak
    the gen lights usually indicate a low voltage problem.
    your situation sounds funky to me I bet you have a few bad wires in your harness someware that are messing with eachother.
    thats why I hate lights I like to see the voltage see the temp see the oil pressure
    Main rig-1978 chevy 3/4 f/t 4x4 8" lift 38 14.5 16 toyo m/t's. BUILT 350(soon to be 6.2) quad batteries. front and rear 15k winches. lockers F/R. dana60 front full float corp 14 rear. th400/np203.
    donor rig. 1988 GMC K3500 140k miles, th400. IFS(read CRAP) semi float 14 rear. drove it 142 miles home at 17mpg and 1/4 quart of delo 400.
