Results 1 to 2 of 2
Thread: Broken Transmission Filler Tube
    Apr 2020
    San Luis, CO
    Default Broken Transmission Filler Tube
    Hello Everyone- I have a 1992 Chevy 6.2 non aspirated over drive transmission. I noticed the automatic filler tube was loose when I was checking. Sure enough the dang thing disconnected where it connects into the frame. Could someone help with a source to buy a replacement with a part #. Sure would appreciate it. Also, replacing the rear shocks (have a heavy heavy Lance Camper- Mono max a good shock to buy?
    Thanks so much for your help.
    Connects to the frame? Or connects to the transmission? I think the tube is press fit - so could just be pressed back into place unless it is damaged.
  1. Broken Transmission Filler Tube
    By sunriver05 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 04-13-2020, 10:10
  2. Allison code list, tq. specs, and other info
    By Bobo in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 01-26-2015, 18:30
  3. Transmission leak at dip tube
    By JackRH in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 07-19-2011, 10:46
  4. oil filler tube gasket
    By Mr. Bone in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 12-19-2006, 11:37
  5. The transmission filler tube
    By Low_Bridge in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 11-21-2004, 03:39
