Results 1 to 19 of 19
Thread: Lift Kit Summary
    Jun 2002
    Oregon & Texas
    I have done a bunch of research on lift kits lately. Here are the high points of what I have found. I will provide more details if desired. I am not a suspension expert, just a customer who is looking for the absolute best solution.
    As much as I love the smooth ride of our trucks independent front suspension (IFS), they have a lot of limitations. Now I do like how I usually can drive faster over rough roads than my brethren with straight axles, though they would beat me in really rough stuff. However, I did not get the truck for heavy off roading. I got it for smooth travel and hauling over rough roads, like when going hunting.
    I am looking at the lift because our HDs are low slung and have tiny wheel wells. With 2"of torsion lift and 285s on 16x8 rims with 4.5" of backspacing, my clearance decreases to about 3/4" when turning the steering wheel 3/4 tavel. This is not enough to run chains, and I do get rubbing sometimes on a moderately heavy bounce when turning.
    The general consensus seems to be 35x 12.5s are the max tire size that our IFS can handle without premature wearing of components, and if you off road hard with 35s you may get the early wear anyway. Realize most of the IFS experience is with the 88-98 trucks, and our HDs do have a sturdier suspension--or so I'm told. Folks that don't off road "hard" have had long life form 35s and even a bit bigger.
    There are four ways to get lift with the HDs.
    Cranking the Torsion bars
    There are even aftermarket keyways (Hill 4WD) that will allow up to 3" of lift in the front. At 2" of lift and below, the ride is very good and the CV axles are not at too bad of an angle. Many guys have run 60-100,000 miles with their HDs lifted this way.
    However, as you go over 3" with the torsion bars, the ride gets choppy. This is not because we are loading the torsion bars more. Raising them simply resets their "zero" point. Their spring rate does not change. What is happening is we are getting the shock absorber too far from the center of its travel and it doesn't dampen as well when we do that.
    I currently have 2" of torsion bar lift and my ride is excellent. Part of this is because I have Bilsteins, but another reason is that I have a 1" spacer under the top shock mount which puts the shock closer to its center of travel.
    While I did think of trying a 2" spacer and maybe getting 3" of torsion lift, I decided against that because I did not want to limit the travel of the shock anymore than I already have. Bottoming/topping out a shock is a bad thing.
    Yes, if we could use a shock 3" longer than stock, we might be able to get 3" of torsion lift with a good ride. We probably wouldn't even hurt our CV axles, as this amount of change is well within their operating limits. However, no one makes such a shock. I also imagine that at 3" of torsion lift we'd want to flip our tie rods.
    I rally don't like having my torsion bars cranked. While it doesn't hurt the CV axle itself, it does cause the folds of the CV boots to constantly rub against each other, which has to incease wear a bit. When the CV boot gets a hole in it, the dirt can get into the CV joints and then they will wear. The good news is CV axles are not that expensive. I was told $60-$70 each.
    Body Lifts
    Nobody yet makes a body lift for the diesel. However, some guys have installed them and made some simple mods. You will need to get some extended fender liners to cover the front wheel wells. Our trucks already show a lot of frame, and a body kift adds to that. If you run an aftermarket bumper like I do, there may be some additional brackets that need to be fabricated. The consensus of those I talked too on body lifts was they are not good for a work truck. Towing would be fine but it might be hard to get someone to install a 5th wheel hitch. You could do it yourself and fabricate spacers for the hitch to make sure it connects to the truck frame, but no one really knows how such a set up would hold up.
    Suspension Lifts in General
    There are two basic kinds--he kind that drops everything and the kind that has longer steering knuckles or spindles. Though two companies advertise 4" lift kits, there are all really 6" kits. I'll explain what I mean later. Most kits require cutting off the stock mounting ears of the front differential, so it would be hard to put the truck back stock with these kits.
    Non-Spindle Drop Suspension Lifts
    These kits lower the entire drive train except for the transmission. They make brackets that drop everything--front differential, steering components, etc, the proper amount. The truck can be aligned to stock specs. The two I have come across are Pro Comp and Superlift. The Pro Comp sells additional components to fix the problem of front drive train vibration when in 4WD at higher speeds. I think Superlift had solved that problem as well. These kits keep the same front track width as our trucks have when stock. Both of them have two piece sub frames. While a one-piece sub frame is sturdier, you probably don't need it unless you are doing some heavy off roading.
    I got to see two lifted HDs side-by-side. Both had the Pro Comp 6" kit. One had 305/70R 16s and the other 315/75R16s. The truck with the 315s was lifted more--the torsion bars were cranked a bit. The 305/70s--same diameter as 385/75s but 3/4" wider--looked great on the truck. The truck with the 315s was a couple inches higher in the nose and almost an inch higher in the tail. The difference in tire size accounts for some of that. The 305/70/16s are 32.8" tall and the 315s are 34.6" tall. This equates to a .9" difference in ride height. However, the truck with the 315s looked much bigger.
    This seems to be the newer technology. The steering knuckles or spindles are longer than stock. These systems keep steering components--like the center link, tie rods, and pittman arm, in the same location relative to the frame of the truck as when stock. This method seems to reduce wear on these components, and these components have been weak points in the IFS in the past. These kits also allow alignment to stock specs.
    I am told all the spindles are made by one or two companies. Also, they say all the spindles have the same amount of drop, whether they are for the Trailmaster 4" kit, the Rancho 4" or 5" kit (It's amount lift depends on which catalog you read), or the Tuff Country 6" lift. In fact, Trailmaster's 4" and 6" kit use the exact same spindles. With the 6" kit the CV axles are horizontal--like stock, and you get a true 6" lift. With the 4" kit the CV axles are drooped (inner CV joint is lower than the outer CV joint) and they give you a 2" lift block for the rear springs vs the 4" lift block you get with the 6" kit.
    I personally don't like a lowered front diff. The reason I got my torsion bar keys and lifted the nose of my truck in the first place was because when hunting on a rough, rutted road, I filled the skid plates with mud and grass because the front diff in the stock location is kind of low to the ground. When I raised it, that problem went away. Most of these spindle kits drop the front diff about 1.5" less than the spindles, so it helps keep the diff up out of the way even without cranking on the torsion bars.
    Last year, the Rancho kit was advertised as a 4" lift, this year it's a 5" lift but nothing has changed. I am told Rancho is always conservative with it's set up, and that they use the same length spindles as everyone else does on their 6" kits. Rancho uses a 2.5" rear lift block. I am not sure how they get down to 4" or 5" of lift with their long spindles, but they do manage to keep the CV axles horizontal and the trucks are level.
    One thing to keep in mind is all the spindle drops increase our front track width. Stock, out trucks are already about 2.5" wider in the front track than the rear. With the Rancho, Trailmaster, and Fab Tech kits, the front track is increased another 1.5" per side, not even accounting for wider tires and wheels. My 285's on 16x8s already stick out past the front fenders 1.5" per side. If I installed one of the three kits I just mentioned, they'd stick out 2.5" per side. Wider tires would be worse. Now the guys with these kits tell me they look fine--and they do. However, they say it is hard to keep mud, water, and debris from hitting the sides of the truck.
    The Tuff Country, RCD, and Skyjacker kits only increase front track width about 1/2" each side. Tuff Country offers a one-piece sub frame. Skyjacker does not require cutting the mounting ears off the front diff, so it is easily reversible. RCD comes with Bilstein shocks.
    I am going to get the Tuff Country kit, mainly because I can order it from a local shop and get it delivered to my door for about $200 less than the mail order places charge. I also like it's minimal increase I track width and it's one-piece sub frame. I'd prefer the Bilstein shocks, but I can do that later if I need to. I'd really rather have a true 4" lift, but nobody is making such a kit. I'll run my 285s for while with this kit. they will look a tad small. Later I will get larger tires--either 305/70s or 315/75s.
    I plan to use the Tuff Country kit and keep my current 285s on 16x8 rims. I will keep the lift on the lower side of the range.
    I have left a lot of stuff out, but I hope I can point folks in the right direction. All the company reps were very helpful, and I think any one of these kits would be a good choice, depending on what you prefer.
    Blaine
    2002 Crew Cab Short Bed 2500 HD 4x4, Duramax, Allison, Amsoil, Magnaflow 4\" x 20\" muffler, Juice,; Fold-a-Cover, nerf bars, Husky mats, Weather Tech windo vent shades; bed mat, tailgate protector, bulkhead protector, wheel-well protectors; mud flaps, Leveling kit, Frontier front end replacement
    Feb 2003
    Fort Worth, TX
    Nice job.
    2002 D\\A CC SB LS 4X4, Isspro Gauges, Hot Juice, AFE Stage 2, TTT Mirrors, Escort Solo S2 and ZR3 Lazer Jammer, T-304 Stainless Steel Nerf Bars and Grill Guard, 2\" Keyways and 1\" blocks in the rear, Kennedy Headlight Booster, Banks Monster Exhaust (Straight Piped) and BigHead Wastegate Actuator, Rancho RS9000X W\\In-Cab Remote, Remote Dual Bypass System, Mega Filter, Totally Redone Stereo System- Alpine 7998\\F540\\M500\\H700(5.1 Sound System)\\S680(DVD)\\XM\\Mobile Hub- Focal\\165K(rear)\\165K2 front)- Two VizuaLogic Headrest Monitors with four wireless headphones - Image Dynamics IDQ 10\" subs in a Probox under the rear seats, CompuStar Remote Starter-Pager-Alarm, 2002 Forest River Wildcat Travel Trailer (Loaded 8000#), 2000 Skeeter ZX185 W/Yamaha 150 (Team Skeeter Package), 2001 Volvo S60 T5 (Wife\'s Car)
    Jun 2002
    Oregon & Texas
    Thanks--I hope sombody finds it useful...........
    Jan 2004
    Great job Blaine...certainly made things more clear for me.
    Jan 2004
    San Diego
    Great post, thanks for the info!
    I am still going with RCD [img]smile.gif[/img]
    <a href=\"http://www.sandbros.com/mikesride/chevy/dmax/super/dez.htm\" target=\"_blank\"> \'04 Dmax CC Short Bed--Dark Grey. CST lift, FOX shocks, 35\" pro-Comp tires w/ KMC wheels</a><br /><br /><a href=\"http://www.sandbros.com\" target=\"_blank\">www.sandbros.com</a>
    Mar 2003
    Fenton, MI
    So, the main difference between the spindle drop and non-spindle drop is whether or not the steering components remain in the stock location? The front differential gets lowered no matter what right?
    Jun 2002
    Oregon & Texas
    I think that's true on the steering components. The best I can tell, yes, they all lower the front diff. Here are some useful links. Please don't rely on my research as the final say, but just as a starting point. You can download instructions form many of these places and see what all is done.
    http://www.tuffcountry.com/suspension_gm_HD.html
    http://www.trailmastersuspension.com...c/chevyhd.html
    http://www.superlift.com
    http://skyjacker.com/products-02chevykit.asp
    http://performancelifts.com/cgi-bin/...D2000GM68.html
    http://www.gorancho.com/Flash_gorancho_main_new.htm
    http://www.fabtechmotorsports.com/html/k2500hd.html
    http://www.californiasupertrucks.com/
    Mar 2003
    Fenton, MI
    is skyjacker the only one that allows the truck to be returned to stock?
    Buck Guest
    You forgot the Solid Axle conversion kit with crossover steering Why not delete the IFS!!
    ORU has a pic on there site of an '03 HD with 42" Swampers . I'm sure nobody here would want a truck this extreme but look at the endless lift choices.
    Mar 2003
    Fenton, MI
    Those are expensive
    Buck Guest
    $850 for the kit. Just need get a Dana 60 (from a '79ish Ford) rebuild it, get the crossover steering and the hydro assist and....
    I think it could be done for under $5k. Hey, some guys are dropping $4-$5k for sun coast trannys!
    Jun 2002
    Oregon & Texas
    As far as I can tell, Skyjacker is the only one that does allow a return to stock.
    The solid axle is appealing sometimes, but my money says it will not ride anywhere nearly as smooth on rough roads as our IFS.
    [ 02-18-2004, 09:51 AM: Message edited by: afp ]
    Aug 2001
    Victoria, B.C., Canada
    The Pro Comp and Skyjacker are similar in design. They both cut a crossmember and supply a weld-in patch. Although Skyjacker is the only one to advertise returning to stock, both of these kits can be removed to returned to stock equally.
    Superlift uses poly bushings in the drop steering bracket, but Pro Comp uses heims. I'll pick the heims for longevity and precise feeling.
    I think Superlift offers a 5" tapered block, where Pro Comp is a 4" non-tapered block for rear suspension.
    FYI, there's a good summary of all kits and different aspects of them over at fullsizechevy.com.
    --Rob
    2002 GMC K2500HD D/A SLE SB EC<br />Banks Stinger TLC System, exhaust brake<br />Lucerix mirrors<br />Deep Allison trans. pan, TransSynd<br />Armaguarded box<br />Hijacker 5th wheel hitch<br />Redline TA 1200 brake controller<br />LT265/75R16 Cooper Discoverer A/T 10-ply tires
    Aug 2003
    Cypress Texas
    Cool
    This is very good info.
    The only thing I do not agree upon is: The R.C.D. and the Rancho lift are the exact same thing. The Rancho is a one-Piece sub-frame and the R.C.D. is a two piece. ( they are lazer cut and welded at the same manufacturer) If you laid a Rancho and a R.C.D. side by side you will see this.
    R.C.D. made a smart marketing Idea by selling Bilstein shocks with their lift. which is why everyone thinks they are the cats meow!
    Personally, from my experience I would avoid all spindle type lifts. ( and also cranking your T-bars)
    I am on my third lifted truck and have driven over a million miles lifted easily.
    CRANKIN YOUR BARS IS THE HACK WAY! G.M. did not design the C.V.'s or the Ball-joints or the tie-rod ends to work at these angles. If you decide to lift your truck by Crankin' your t-bars or using a spindle type lift, be prepared to start replacing these parts.
    [ 02-18-2004, 06:28 PM: Message edited by: Yellow '03 H.D. ]
    Jun 2002
    Oregon & Texas
    Yellow,
    Good input, let's discuss this a bit. I am going to ask you some challenging questions, not to start an argument but to pick your brain for some more details so I can understand all this better.
    If I remember right, the RCD guys told me their spindles--like the Tuff country and the Skyjacker--only increase track width by .5" each side where the Rancho increases track 1.5" each side. I have not seen an RCD kit. Do they have the 1.5" wide axle spacers like the Rancho?
    Why would you avoid spindle lifts? They have the advantages of keeping the steering gear in it's stock location, strength, and simplicity. A couple do increase track width excessively, but many do not.
    I don't really like the cranked torsion bar idea myself. However, it isn't the issue with the HDs I guess it was with the 88-98 IFS rigs. GM did design the HYD CVs to be operated at increased angles. You can take off the shock and drop the A-arm all the way to the stop, and the CV will not bind. However, the boots sure do rub against themsleves a lot at increased angles, and that must wear them out sooner. Once the boot goes the CV joint won't be far behind.
    A problem I have often run into is the experiences that applied to the 88-98 IFS do not alwats apply to the HD IFS. I have come across many guys who have run their HDs with cranked torsion bars for 75,000 - 100,000 miles plus with no wear issues. One of these guys I know personally, and he drives on pretty rough stuff. While I still don't like it, too many guys have had good expereinces doing it for me to consider it a distater waiting to happen.
    Having said all that, have you run across guys with HDs and cranked t-bars that have had prenmature CV joint wear?
    Blaine
    Buck Guest
    I will agree cranking the torsion bars is not the proper way to gain lift but.....you know how easy it is. I would ONLY use the factory torsion keys, I feel the other keys take things to far . I cranked mine a little to clear my 285's, just be sure to get it realigned after your done .
    As Michael Tomac and others have found, running at the track in higher boost 4wd launch situations with torsion bars cranked ultimately ends with broken tie rods! The steering components are the weakest links. Michael is also running a Eaton E locker up front
    [ 02-19-2004, 08:53 AM: Message edited by: Buck ]
    Jun 2002
    Oregon & Texas
    Buck,
    Full stall 4WD launches with the 215hp box Tomac has--cranked t-bars or not--is going to break stuff..................
    BTW after cranking all you need to do is reset toe--raising the nose with T-bars toes the tires in some more.
    Also, the aftermarket keys are a probably better choice if you want to raise the nose more than an inch or inch and a half, as sometimes factory keys will bind past that point. It seems to be dependent upon the truck.
    BTW, check these out: http://***********.com/forum/forum_p...?TID=5437&PN=1
    Aug 2003
    Cypress Texas
    Yes the R.C.D. uses the same 1.5" spacer as the Rancho.
    The reason I would avoid a spindle type lift is they only lower the diff. 4" and the axle is lowered 6". This creates a bad c.v. angle.
    It is my opinion this is the reason why I have exploded 2 c.v.'s on my 2000 1/2 ton chevy.
    The c.v.'s on the H.D.'s are a lot stronger than the 1/2 tons.
    Jun 2002
    Oregon & Texas
    I guess things are always changing. The Tuff country kit lowers the diff 5" in the rear and 6" in the front--that is the size and shape of the front diff lowering bracket. This keeps the front driveshaft at the proper angle and the Cvs at the factory setting.
    Regardless, I wish they'd just make the trucks with more wheel well clearance at the factory............
