4L80e + NP-246 is a problem w/standalone controller
Aside from the TPS any rig w/NP 246 AutoTrac has 3 speed sensors that sense frt driveshaft speed, rear driveshaft speed and road speed then the ABS is intergrated into that making for a PITA project going to standalone tranny control.
Reason for the 3 speed sensors, the NP246 has a clutch pack 9 clutches and 10 plates, when in autotrac everything comes into play and when slippage/or different speeds are sensed controller adjusts clutches as needed.
Any other t-case does not have the complex setup as a rig equipped w/NP246 does.
Hopes this helps ya!
