wrong sender
Sounds like you've removed the Fast Idle and Timing Advance switch that is located on the passenger's side rear cylinder head near the firewall. This switch (not sender) has two wires on it. One wire is power, the other wire goes through the harness to the injection pump and fast idle solenoid.
So, put this back in.
The sender you're looking for is located on the driver's side of the engine bay, at the front of the cylinder head, just above the powersteering pump, or below the a/c compressor.
It just has 1 wire on it.
My recommendation:
Purchase a blockoff plate for the rear cylinder head that has the 1/2 threaded inlet on it and mount your new gauge sender there. This will be the HOTTEST coolant path on the engine. Then, leave the factory gauge AND cold advance Switch in place and functional. You can use the factory gauge AND your new aftermarket gauge and compare the two, for a reference.
J
1986 C10 SCLWB 6.2TD 3.73 700
1989 V20 SUB 6.2NA, 3.73 400
1994 G20 VAN 6.5NA, 3.42 60E
1996 K30 DRW 6.5TD 4.10 80E
