Thread: 94 6.5 cranks normally but no start
    Jun 2020
    Canada
    Default 94 6.5 cranks normally but no start
    Hey guys! New to the page. I have a 94 2500 6.5l.
    So I was daily driving my truck, it was sitting for maybe just over a day and I went to go start it and it just cranks but doesnt want to fire. I changed out the fuel filter and nothing changed. There's white smoke coming from the exhaust so I think it's still getting some amount of fuel. Anyone experience these problems or have any ideas?
    Welcome to TDP
    White smoke is un-burned fuel.
    Glow plugs
    Does the glow plug lamp come on and go off when you turn the ignition on ????
    Check to be sure the glow relay is putting 12V to the plugs.
    Check the plugs to see if they are working.
    Pull the plugs on the Drivers side (Easy to get to)
    Be sure there is power to the plugs...
    Possibly the glow relay is bad
    If there is power to the plugs then you may have bad plugs.
    Screw in four Delco 60G plugs.
    4 will get it going....
    Keep us in the loop.
    Jun 2020
    Canada
    So took a better look at it and I guess my valve cover leaks because my glow plugs are covered in oil.. anyways that's a project for another day lol. All terminal ends broke off of the glow plugs.cracked open the female terminal and they're soaked in oil, so I guess that might play a roll lol.
    Anyways, I go to remove the glow plugs and they seem pretty seized in there, little worried of breaking the glow plugs in the head, think I'm going to soak them with some penetrating oil for a couple days before I attempt to remove them again
  1. Tahoe Cranks But Won't Start
    By Stratosurfer in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-15-2011, 18:45
  2. No glow plugs, cranks, but no start
    By jf-schaack in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-10-2011, 06:24
  3. 6.5 won't start, only one dash light
    By 6.5guy in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 05-06-2009, 19:27
  4. 6.5 Shuts down, no wait to start light
    By mweed22 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-19-2007, 12:49
  5. 6.5 won't start
    By farmerherb in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 06-11-2006, 09:01
