It seems that there's quite a bit of talk all around this subject, but I haven't found any real definitive conversation about it. So I thought I'd get a thread going and see if we can nail some good info down.
Let's assume that fuel contamination (particulate & water) is bad for our engines in general. Let's assume that it contributes to the injector failure rate (not causes, but contributes). Let's assume that filtration is an overall good thing if done properly.
Okay, now given all those assumptions:
1) What is the filtration cabability of stock filters in microns?
2) What is the flow rate of stock filters in GPH?
3) What would be the recomendation of an aftermarket filter....2 microns...10 microns....30 microns?
4) What should a good reliable flow rate be?...15 GPH....30 GPH.....45 GPH.....60 GPH?
5) Where should the filters be placed in respect to the original filter?
6) Anything else you can think of.
I understand from other posts that GM is/has just come out with new filter recommendations to combat the injector problem...or some of them. Or at least help with it. This seems to me that they are conceding that filtration can be better and that it can help out with some of the injector issues. It would also seem that it would take some of the argument away from them in-so-far as warranty issues pertaining to aftermarket filtration.
I guess what I'm hoping for is enough good, solid information so we can make a good decision on whether we should add filtration and, if so, what kind of filtration.
\"All I know is what I read in the papers\"<br /><i>Will Rogers</i>
