TheDieselPage.com Forums
The Diesel Page Forums
2020 - TDP's 24th Anniversary
Go Back   TheDieselPage.com Forums > 2001-2019 Chevrolet & GMC 2500HD/3500 Light Trucks > Duramax 6600
Reply
Thread Tools Display Modes
  #1
Old 06-18-2019, 09:57 AM
ebenton2ph ebenton2ph is offline
Newbie
Default water pump, turbo, whirring noise
I recently changed the water pump on my 07 6.6 duramax. Since then I have a whirring noise on acceleration. Could this be related to the water pump or is it a problem with the turbo?
  #2
Old 06-18-2019, 11:50 AM
rapidoxidationman rapidoxidationman is offline
Newbie
Are you sure the seal on the exhaust end of the egr cooler tube is solid? A slight exhaust leak there will sound like that.
  #3
Old 06-18-2019, 12:10 PM
More Power's Avatar
Administrator
Quote:
Don't know about the whirring... but
Water pump seal leaks...
I have had water pumps on the 6.5L diesel last for 300k+ miles. I know of a Duramax water pump that lasted for at least 750k. These seals should last longer than any of us need them to.
Water pump seal leaks occurring in any diesel engine are more often than not caused by excessive pressure in the cooling system (combustion pressure finding its way in - due to bad head gaskets, EGR leaks, head crack/porosity, LB7 injector cups, and so on...
A quick check of the firmness of the top radiator hose after sitting overnight will reveal a cooling system overpressure problem.
  #4
Old 06-19-2019, 11:02 AM
Kennedy Kennedy is online now
Long Distance Crew Chief for BMDMAX
The fist question I would ask is what did you use for a water pump? The proper LBZ/LMM water pump has a composite impeller with an aluminum hub. I see a good number of listings for cast impellers which is a big mistake to go with.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
