TheDieselPage.com Forums
The Diesel Page Forums
2020 - TDP's 24th Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Forums > 1982-2000 C/K Truck & SUV Chassis & Drivetrain
1982-2000 C/K Truck & SUV Chassis & Drivetrain Discussion Forum for the 1982-2000 GM Pickup Trucks and SUVs, and their Transmissions & Drivetrains, cab, chassis, electrical systems and a lot more.
Reply
Thread Tools Display Modes
  #1
Old 08-25-2019, 04:29 AM
BorJansson BorJansson is offline
Enthusiast
Default Door panels ?
How to dismantle door inner panels.
Most worried about the panel with electric controls and to get the panel off the door without cracking any plastic details.
K1500, extended cabin, 6,5l w.turbo
BorJan
__________________
1989 Buick Le Sabre Estate Wagon w. 6,5l diesel + THM700r4
1994 Chevrolet Silverado Stepside ext.cab
1962 Harley Panhead
1962 Volvo PV
1959 Fordson Dexta
  #2
Old 08-25-2019, 05:24 AM
DmaxMaverick's Avatar
Administrator
Working with old, brittle plastic is always risky. Expect some damage to tab type fasteners, no matter how careful you are. If you don't break any, consider that the exception, and not the rule. There are specialty tools that minimize damage, but they are often prohibitively expensive or unavailable for the DIY'er. A couple common and simple tools that are really helpful are wedges and long-reach tools. Handy wedges, such as plastic felling wedges (used for felling trees) can be found at hardware and home improvement stores (and anywhere that sells/services chain saws). Long reach tools can be anything from screwdrivers to weed-popping tools. I like the weed poppers (long screwdriver like tool, with a wide, flat, forked end, robust handle, usually with a couple slight-angle bends, and about 20-40 cm long, modify as necessary). You can also fabricate a good long reach tool by simply flattening the end of a length of metal rod. Good lighting is also important, so have a good flashlight handy. Check everywhere for screws, especially embedded into carpet panels (screw heads will often be below the pile surface).
Anyway, most GM vehicles aren't too complicated, but there is usually a lot of plastic fasteners, retainers, and aligners involved. Breaking some of them may be unavoidable, but most often can be restored with a little ingenuity. The metal clips over plastic tabs almost always weaken their grip once removed, so rebend them a little so they grab a little more once reinstalled to prevent rattles and maintain alignment. Most panels are secured at the bottom edge with screws and/or friction fasteners/tabs, and metal edge clips at the top (once the bottom and middle fasteners are free, the top lifts up and away). Youtube is also helpful for getting a look inside a panel before you dive into yours. Most folks make note of hidden fasteners. Let them show you how they broke theirs before you break yours. Even good drawings are not of much help. If you have power windows/locks, simple connectors are almost always accessible, and some are removed with handles and levers before removing the panel.
If you are repairing a window motor, it's always a good idea to replace the register and lubricate tracks, as well. Slow power windows are very often a combination of tired motors and worn registers. Plastic guides work much easier with a little silicone grease to slide on. It's also a good time to replace old radio speakers, sticky switches and weather strips/wipers. The key to solid door panels is removing them as little often as possible, and restoring fasteners as much as you can. Every time they are removed, they go back on little looser than the last time.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
