Results 1 to 10 of 10
Thread: engine stalls no wait to start light
    Default engine stalls no wait to start light
    1997 Burb 2500 stalls about ten minutes after startup or won't start at all. No wait to start light some times you can hear relays chattering ( the ac clutch will chatter if the defrost is on) then for no reason it will start working after you cycle the key. If you try to start with out the wait to start even when its warm it still won't start. Had a local diesel shop look at it and when it failed mechanic couldn't get scanner to talk to PCM but it did have power going to it. Replaced ignition switch year and a half ago, FSD and cooler year and a half ago also lift pump about the same time.(less than 15,000 miles ago). It seems to happen on colder mornings especially with a large temperature swing.(40*F). Cleaned and added new grounds also did the battery terminal updated. Did a wiggle test on harness and on pcm. Can't seem to find anything I'm about to throw a PCM at it but hate to spend money and have same problem. HELP!!! (also not giving any codes when this happens)
    Sep 2000
    usa
    Those symptoms indicate failing connections - power, ground, signal.
    Something eluded you, or something occured after your previous checks.
    Start at the battery terminals, both positive and negative - look for oxidation, corrosion, loose connection at both ends, incl starter connection.
    Check the main harness grounds at the rear of the intake manifold, and the connections at the fuse block center.
    Check the connections at the power block on the firewall.
    Check the harness down by the evaporator low pressure line where it exits the firewall for frayed wiring.
    Check all the main harness connectors behind the fuel filter, also the harnesses down to the transmission and lift pump.
    Also check the connector to the ABS module - try pulling it, see if PCM recovers.
    jd
    You could also probe the various ECM & ignition fuses with a multimeter to determine whether they have power - when this occurs.
    Default update
    Heres an update to were I'm at. Removed and cleaned all battery terminals, added a ground wire from passenger side battery to engine block second post from firewall on passengers side, also moved the pcm grounds (20awg black/white and tan/white) to same stud also continued same wire to chassie ground for the hood and continued to drivers side battery and attached it to frame on drivers side. Ceaned ground straps on passenger side. Removed and cleaned the feed for fuse block in engine compartment, also pulled fuse block out and inspected the underside. Checked the PCM grounds at pcm connector to chassis and had about 2 ohms. Cleaned all connectors on firewall (scraped pins with small screw driver). I check the power a the PCM after it stalled and had 12v between orange wires and pcm ground also checked pink wires and pcm ground. Wiggled wires to ignition switch and still no luck. Also removed wiring harness from firewall and inspected. The truck will stall randomly sometime just cycling key and it will restart and run fine, other times the fuel pump relay and AC relays will just chatter (while they were chattering wiggled power, grounds etc. ) then just stop and every thing is fine. Also pulled the PCM and removed covers, visual inspection of board nothing appears burnt loose etc.. Not really sure what gmctd is calling the power block on firewall. I've yet to check out the ABS stupid thing idled over an hour and wouldn't fault. Open to any suggestions (minus setting the POS on fire as my wife suggested). Thanks (sorry so long winded)
    97 GMC Suburban SLT, duals cat back, FSD cooler, 4L80E, 3.73 pretty much bone stock.
    Default same problem with my 3500 sierra
    I am having the exact same problem with my 3500 sierra - exact problem. It has been in the shop twice for this, and I have spent around 1300 dollars on it. It will run fine for a couple of days, and then just quit and won't restart. After sitting around for a couple of days, it finally restarts, and runs fine for another hundred miles or so, and then the same thing.
    I too appreciate all the responses to this question.
    Dec 2006
    What parts have been changed?
    95 C1500, IC, 3" to 4" Exhaust, Turbo Master, Max E Torx.
    Jul 2002
    Michigan
    "The truck will stall randomly sometime just cycling key and it will restart and run fine"
    Sounds like classic signs of failing ignition switch, these trucks had known issues with bad ign. switches [poor contacts inside switch], '95 and up IIRC.
    Default update II
    Still stuggling with this truck. I never thought I'd be begging it to stall!! Hard to fix problem when it won't return. I've pulled, wiggled, hit the ignition switch and wiring and no problems. I'm going to back probe the pcm when it finally faults.(checking power in and power out) Its been starting fine in -0 weather and running fine. I'll just carry my multimeter and wiring diagram and wait for it to fault. Or just have my wife drive it (it seems to only have problems when she is driving it).
    Formerly Scotland, Now Alberta, Canada
    Hi,
    D350diesel is having similar/same trouble as you and I've also had the same but so intermittent it is impossible to pin down.
    Keep an eye on his thread in case his experiences help us all get to the cause of this problem.
    http://www.thedieselpageforums.com/t...ad.php?t=25975
    I would be happy/relieved to get to the cause of this problem as The Suburban has done this for a couple of years now. Usually it is 4 or 5 months between the problem occurring but recently in the last few months it has happened once every few weeks which makes it virtually impossible to diagnose.
    My Subs problem usually starts with the engine shutting down while driving (nearly always on light throttle or slowing down at a junction), sometimes can fire it up while still on the move. Other times I have to wait 5 minutes or so.
    Same thing as you guys are getting No "wait to start" light which indicates to me that there is NO POWER to the glow plugs and as it won't fire up, no power to the fuel injection pump.
    I have started to carry a multimeter but seldom have long enough to do proper checks because it usually fire up so quickly. And then it'll be fine for several weeks or months.
    Good luck
    Biggar, Scotland
    Sep 2000
    usa
    You've worked thru the problem areas, now pull the ign switch, disassemble it, see what you got.
    And, if that is a ground at the PCM, 2 ohms is not suitable - 1amp thru there and you got a 2v drop.
    The '94-'95 trucks have a big power block on the top passenger-side firewall - yours may not have that.
    jd
