Page 1 of 3 123 LastLast
Results 1 to 20 of 46
Thread: The P0087 Saga Continues
    Geneva, IL
    Default The P0087 Saga Continues
    Hi,
    I’m modifying and moving this content from the Sticky I previously had posted in, to try to get some feedback. Moderators, if this is a problem, feel free to delete.
    I just returned to Illinois from Quartzsite towing my 12,000# fiver. I have 123k miles on the '09 LMM at this point. I had no problems going down in January, but several P0087 episodes on my return last week – big hills, a couple hours into the day, lower fuel level in the tank (the usual culprits, evidently).
    This is an absolutely stock truck, with auxiliary filtration, regular Power Service throughout its life, regular filter changes, and regular Chevy dealer service at the same competent location. No lift pump (duly noted, John).
    Obviously, working through the P0087 Sticky thread gives possible short and long term answers. But my solution for getting home the last 1,000 miles -- starting in western Oklahoma -- was to keep post turbo EGT's in the 1,000 degree range, and never more than 1,100. I used that as a proxy for the temps the injectors and incoming fuel were experiencing. I did this by doing a lot of manual gear selection on hills. (I recall only one post in that entire Sticky thread that mentions that approach.)
    My dealer has just had it for two days, and as I expected, found nothing wrong. The injectors tested solid (as they did just before I left actually). No codes were remaining, of course. And absent the load from towing a heavy trailer on hills for hours while hot, there was no way to get their equipment to register my issue. In addition, at my request they inspected all fuel lines (solid or already replaced), the fuel cooler (clean), and they found no leaks anywhere.
    These are two guys who know the truck since new, have serviced it thoroughly and regularly, and otherwise have my confidence. They did offer a thought that freeing up the exhaust might help keep overall temps down and thus keep the returned fuel cooler. Coming from a dealership, I found that interesting.
    But for now I'm guess I'm going to drive on carefully, and see what the future holds.
    Any thoughts on the exhaust change idea from anyone? How about my strategy of using EGT as a proxy for fueling performance? Or for that matter, on any other recent developments on this P0087 code problem for medium age trucks that work hard?
    Thanks for your ideas.
    Rich Phillips
    Member #27
    2019 K-2500 Crew Cab Z71
    Cedar Creek Silverback 33RL Fifth Wheel
    In The Past: '82 6.2 Jimmy Blazer, '93 6.5 GMC K-2500, '01 DMAX K-2500, '09 DMAX K-2500
    Geneva, IL
    Default A related question
    Hi,
    Thinking about this some more...
    If I go down the road clearing my codes as they pop up (something others have done), does that accelerate wear in the injectors, speeding their eventual demise?
    Rich Phillips
    Member #27
    Rich, the following two subscriber articles appeared here some time ago. They were written to help address the trouble code P0087 in the LMM trucks (and earlier LB7/LLY codes) that correspond with rail pressure problems (difference between commanded and actual fuel rail pressures exceeding 20Mpa).
    Are high mile injectors allowing too much return fuel, which result in a P0087? GM shows in their service manuals how to perform a fuel return test using graduated cylinders that helps the technician measure fuel return flow over time. The first link shows the test setup, and explains how its used.
    https://www.thedieselpage.com/members/features/p0087c.htm
    https://www.thedieselpage.com/members/duramax/April2008DTCc.htm
    Techs tell me that a lot of trucks that approach their 10-year mark frequently have surface-clogged fuel return coolers. Mud, leaves, you name it, all restrict air flow over/through the cooler.
    Geneva, IL
    Hi Jim,
    Thanks for that response. I had read the first linked piece, but not the second one. The Sticky thread and John's tech piece rounded out my major research.
    The bottom line seems either to be that this generation of injectors is vulnerable to wear and/or fuel viscosity changes, or the ECM programming is dysfunctionally narrow. (I include the latter because John seems to have attacked it somewhat successfully from that angle.)
    My hoses, filter housing and filter have been replaced. The injectors all are strong in every test in the shop. The pump is putting out per spec. My GM guys have checked the cooler and lines, and I will do that again when I get some decent weather. (We just talked this morning about the possibilities of an auxiliary fuel cooler.) But there is no way to get them involved in more useful testing 200 miles into a day, going up some big hill towing a 12k trailer -- duplicating the problem with prolonged, sustained load and elevated temperatures. I can drive it all day unloaded in any weather, with no problem.
    You know I love GM products. But pickup trucks built to work -- as our diesels are -- surely could have more longevity built into key, very expensive parts. Or is this the unavoidable legacy of always-advancing emission requirements and associated engineering compromises?
    Color me frustrated and mildly disapointed...
    Rich Phillips
    Member #27
    I talked to a guy a few years ago who had a 2009 model he used to pull a 5ver that was experiencing the P0087 code problem... till he installed a large auxiliary fuel tank in the bed of the truck. He ran a fuel transfer system (don't remember the details) that cycled fuel through the aux tank and his frame mounted tank. This effectively ended his P0087 problem. Hot thin fuel, as he discovered, was a key factor in his P0087s, or at least cooler fuel masked the root cause. Jim
    Lift pump, tune it, drive it. If the conditions still exist the P0087 will set and check engine light will be on but truck will drive right through. If the instance increase significantly it's time for injectors.
    I'll also note that I have done tunes for trucks that have had GM sourced injectors installed and NOT fixed the issue. I've had guys change injectors and repeat in less miles than the originals as well. Tune and move on
    As for the testing quite often they will pass the stationary tests as the temp/psi/time does not accurately simulate real world.
    That or just take my word for it having had injectors bench tested and seeing the obvious fail its the reason
    Geneva, IL
    Question
    Hi John,
    Thanks for your additional input. Your published materials on this also have been quite helpful to me.
    Do you or anyone else know what pressure exists in the return lines from the injectors to the tank? An additional option I'm considering is a second fuel cooler, but location could be an issue, depending on the available hardware. Something like this...
    http://www.jegs.com/i/Derale/259/132...RoCsDEQAvD_BwE
    Any thoughts, anyone?
    Rich Phillips
    Member #27
    Return line pressure should be minimal. There is an orifice at the end of the line but it's open.
    Cool it all you want, put a fan on it even. I've seen it all. Sometimes you get lucky, but most often not.
    If I were faced with this P0087 problem, I would do as JK said... Add a lift pump, retune the ECM to accept a wider tolerance for an acceptable common-rail pressure differential, then keep driving it till injector replacement becomes unavoidable.
    Geneva, IL
    Hi,
    Yeah, but that is a tough pill to swallow if there is even a modest chance a second fuel cooler, better management of the level of fuel in the tank, or other less costly options could have promise.
    This is doubly hard for me. First, we buy these trucks because they are supposed to work long and hard. And I don't readily accept the proposition that 120,000 miles is acceptable life for such high cost components. Second, because to adopt the strategy suggested in the above paragraph, I'm resisting the considered advice of two guys whom I respect, and who know a lot more about this than I do.
    Color me conflicted...
    Rich Phillips
    Member #27
    Rich,
    I've received quite a few emails and phone calls where the truck owner expressed dismay or even anger over the possibility that the injectors needed to be replaced. It's never-ever a good time. Most believe the injectors should last for as long as they own the truck.
    This bristling resistance to injector replacement happened a lot less often with 6.5L diesel owners, largely because the injectors were/are a tenth the cost. 6.5 injectors needed to be replaced when engine roughness, start-ability, fuel economy or performance said it was time, which usually wound up being in the 100-150K mile range.
    Additional coolers, aux fuel tanks and other less costly attempts to solve the problem might help, but not likely long-term. A hot summer day, a heavy load and hot thin fuel are hard to avoid for some truck owners.
    I know a guy (and you know him too) who simply traded his truck in for a newer model when faced with the same situation. That's one way to deal with it.
    Another way to deal with it is to acquire an aftermarket engine warranty that covers the fuel injection system, once the factory warranty expires. This... could be the best way to deal with the specter of a breath-taking repair bill. Insurance coverage for the fuel injection system won't be cheap, but it'll be easier for most owners to deal with than spending a thick stack of $100 bills on injector replacement.
    When it's all said and done, at the end of the day, and after the fat lady has sung, following JK's advice really is the best choice for those P0087 owners who are without an extended warranty.
    Geneva, IL
    Hi Jim,
    I know, I know.... But the Sticky sadly relates instances where neither John's fix nor new injectors were a cure. That's a pretty daunting prospect.
    For sure, the days of me changing fifty dollar 6.2 injectors in my driveway are long gone.
    Rich Phillips
    Member #27
    Dec 2002
    Teton Valley, Idaho
    Question for the OP, and for others who have experienced this problem:
    Do you regularly use a fuel additive at each fill-up or do you burn the fuel as it is dispensed from the filling station pump?
    Geneva, IL
    Hi rapid,
    I have faithfully used Power Service since day one, in every tank. Auxiliary fuel filtration almost from day one, with regular filter changes.
    Right now I'm sort of looking for some old posts I vaguely recall about bad fuel caps and power codes. But in any case, today I was reduced to digging out my old -- but essentially new -- stock cap and replacing my locking cap.
    Of course I will not be able to test any theory until I tow again on a long trip in warm weather.
    I must look pathetic to John Kennedy (grin) But investing the combined cost of his lift pump and tune on a 123,000 mile truck gives me pause, particularly when scattered posts in the Sticky indicate that not every older truck with 0087 gets fixed by going that route (and scarily, or even with new injectors.)
    Rich Phillips
    Member #27
    Ft. Wayne, In.
    Rich,
    I'll second Jim's advice to follow JK solution. Your dealer techs see a small subset of Trucks sold in your area. So they may have see a few that are having issues like you are seeing.
    In JK's case. His business is like a lightning rod for problem trucks. He sees trucks from all over the country that seek him out to cure this same problem.
    Looking at the cost of his suggested cure isn't that bad compared to an injector replacement or truck replacement. Call JK and enjoy life!
    dave
    Dave, N9LOV
    Member #242
    Dave's Diesels:
    '97 2 Dr Tahoe, Intercooled,
    Kennedy ECM, 4" Exhaust
    '02 GMC
    I also have to get this in here.... When faced with the cost of new injectors some owners look online for cheap parts. I should post a montage of messages I've received some day from owners who bought a set of injectors on eBay, Craig's List or even Amazon, thinking they'd save a couple thou $ on costs....
    When asked about the cheap stuff, I answer by saying that the cheap part sellers aren't Bosch reman centers or even authorized Bosch dealers. Many of the parts are super cheap overseas copies that fail soon after installation - if they even work at all. Then, what happens is the owner is out the cost of the cheap stuff, the labor to install them and the cheap part seller has to be held at gunpoint and forced to take them back. It's such an awful experience that some truck owners give up on their diesel pickup.
    So, only buy your parts from dealers who have a reputation to defend. For most of us anywhere in the country, this means buying parts from your local Bosch reman/retail center - or vendors who advertise here. Only vendors who take care of people advertise here.
    Geneva, IL
    Hi Jim,
    Duly noted....
    Just got off the phone with John Kennedy, setting up a trip to the north country.
    Rich Phillips
    Member #27
    To answer your question about whether a performance-oriented exhaust system could help lower exhaust temperatures, I actually performed an extensive test some years ago using a Duramax powered truck I owned to answer that question. Here are the results from that towing test (towing a 7,000-lb trailer on a 6% grade). As you can see, the exhaust temperature remained the same for each run, though there was a measurable improvement in performance.
    Stock power w/stock exhaust: Boost 21 lbs, EGT 1275 degrees, speed 62-mph 4th gear
    Stock power w/Magnaflow exhaust: Boost 21.5-lbs, EGT 1275 degrees, speed 64-mph, 4th gear
    You can see the full exhaust system review here:
    https://www.thedieselpage.com/reviews/magnaflowc.htm
    Geneva, IL
    Hi Jim,
    Thanks for the link -- interesting info.
    I've driven by the EGT and boost gauges since I started running turbos years ago. I always felt that the EGT in particular was a critical representation of what is going on in there, and that managing those temps conservatively is a good way to prolong the life of the engine.
    Rich Phillips
    Member #27
    Add to the list Diesel Logic, Diesel Care, Injectors direct, Pensacola etc. These are common names that I hear when people call with issues on trucks with "new" injectors. Sad part is I don't know where they go, but I seldom if ever get an opportunity to sell these callers the good stuff.
    The only source I trust is Bosch to do the actual reman these injectors. Even my performance source does not waver from this and uses only the real deal as foundation for any custom work. There is one man in a major shop in TX that I dealt with on injector projects back in the early days that has a reman program that I think I could trust, but it's just so much safer to stick with the real deal.
