A-310, I ran a 3-71N off and on for 10 years in a 79 Chevy crewcab. Some times I used a 454 and some times I'd put in a 6.2 diesel. I liked it real well but it was very heavy in the front. It was 2WD and when you got off the road you might as well forget about going very far. I was hauling boy scouts into a camping site and had to go up a small hill and it was a little wet and I just barely got started up and lost traction. A little 4WD Toyota had to pull me in. You have to have an overdrive transmission or very tall tires to get any road speed with a 71 series. I had a 25% overdrive and 3.21 1 ton axle. I now have a 4-53T in the truck with a 5 speed direct drive transmission and a 3 speed auxiliary that is abot 27% overdrive and still have the 3.21 axle. It's been in there 13 years with no other swaps.
A 4-53T weighs 1300
3-71N 1525
4-71N 1780
4-71T 1830
6V53N 1485
6V53T 1695
I believe the best one to go with is the 4-53T, mine is supposed to be 170HP and it definitely runs better than the 3-71N did.
You will have to make motor mounts and brackets to mount the belt driven accessories. This forum
http://autos.groups.yahoo.com/group/DetroitDiesel/ has a lot of good info for Detroit swaps. They say your RPM at cruising speed, say 65MPH or what ever speed you plan to cruise at, should be 2,200- 2,300 for a 4-53N and 1,800 -1,900 for a 4-53T. That's where you get the best economy.
My avatar is the 2 transmission in the truck.
