Thread: 07.5 Silverado 2500 LMM 4x4 problems
    Mar 2020
    Paw Paw, MI
    Default 07.5 Silverado 2500 LMM 4x4 problems
    When I got the truck, the 4x4 didn't work. I replaced the switch, the actuator, and checked the wiring.
    Since then the 4x4 had been working, but whenever I engaged it while in drive it made a short, loud grinding sound, but it worked alright until I went to disengage it, and it made the same sound.
    Semi-recently it started to shift into 4x4, same as it was. Then when I went to disengage it, the 2wd light will flash for a minute before the service 4x4 message came across the dash. If I did the transfer case reset procedure, it would go back to 2wd until the next time I changed it back.
    Now the 4x4 won't engage at all. It says it is working, but the rear tires still just spin. No action at all in front.
    Dec 2002
    Teton Valley, Idaho
    Got any fluid in the transfer case?
    ......or the front diff?
  1. 1995 Chevy 6.5 TD 4x4 Silverado HD
    By jmpidgeo in forum TDP Classified ad forum
    Last Post: 12-16-2006, 11:38
  2. 1999 2500 TD 4x4 Burb FS
    By DA BIG ONE in forum TDP Classified ad forum
    Last Post: 08-05-2006, 04:41
  3. 2003 SILVERADO LT 2500 HD 4X4 DURAMAX - $14500US on ebay
    By KenZ in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 10-05-2004, 06:47
  4. 1999, 2500 4x4 Suburban SLT
    By befland in forum TDP Classified ad forum
    Last Post: 07-28-2004, 12:01
  5. Proper towing of a '02 Silverado 3500 D/A 4x4??
    By Penngrovian in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 10-17-2002, 19:44
