Hello everyone,
New poster here, looking for some comments from you knowledgeable guys, and ladies maybe. Thanks in advance. I have searched the forum for this problem, but couldn't find anything. Low compression yes, but crazy high, no.
About a year and a half ago I found a Burb in good condition. I knew it didn't start real good, as the seller had warmed it up before I arrived, and even then it didn't start great, but it had a lot of positives and I had a good feeling about it, especially since there were quite a bit of maintenance notes, so I went for it. Within a week the water pump, original one I believe, started leaking, at about 190K. So I parked it for almost a year, and in the meantime I bought all four books on the 6.5 from this website and the CD, good job Jim and thanks, and I read these books on my long work trips abroad, and eventually did the water pump upgrade and dual thermostat upgrade, with lots of new hoses, and it worked out real well. Now that I've learned more about the rig, I see that the two previous owners did some good upgrades to it, as listed in my signature below.
Now I decided to address the unsatisfactory starting. Plan was to change all the original good stuff, injectors, glow plugs, lift pump maybe, and so on. But I wanted to do a compression check first, since if that's bad, nothing will help. I wasn't expecting bad numbers because the rig drives so nice, good power, no smoke etc, doesn't burn much oil. I haven't done a compression check for ages, and did the mistake of doing it on a cold engine, since I took a lot of items off to be able to remove the glow pugs on the right side. The numbers were awful, I thought I might have to scrap the truck. Most were mid 200s with a couple at 300. Then I learned from the internet how important it is to do it on a warm engine, and the importance of good batteries and starter. So I charged up the batteries fully and changed the starter and jumped out of my skin when it started on half a turn of the key, I just wasn't expecting that! So I guess that was the main problem, the starter. But since I want to keep the truck for a long time, I thought I'd still do the compression check properly on a warm engine, just to know what I have. Coronavirus lock-down everywhere and Amazon not delivering quick, so had to get a diesel gauge from NAPA. Did a couple of cylinders and was getting crazy high readings, and I guess the 1000psi gauge couldn't handle the 750psi I was getting and failed. Took it back, told the guys there that my engine should be 500psi max, when new, yet this gauge was giving me 750psi and then failed, so it's obviously faulty. Got my refund and researched gauges and ordered a glycerin filled analog Mityvac unit, feels like a real quality tool, I like it a lot.
Yesterday and today was spent putting in some good stuff that I ordered, Bosch injectors, ACDelco glow plugs, heat sleeves, had the original turbocharger rebuilt. I was tempted to just put it all together and be done with it, but I convinced myself to do the compression check after all. So I put it all together minimally and warmed the engine up until the temp stopped rising, ran it for about 30 minutes, shut it off, and took the turbo off again to get to the area on the right side, took all the glow plugs out, and proceeded with the compression check with my quality new gauge. Holy Smoke Batman, I got some reading that I did not expect. Can anyone tell me what is going on ?
I started on the driver side and worked my way around clockwise. Cylinder 1-725psi, 3-715, 5-720, 7-870, 8-820, 6-810, 4-905, 2-840.
Did number 1 again, got 615, but felt batteries getting weak, so changed them out, as had some fresh ones ready. But now number 1 couldn't get pressure. Tried a few times, each time disconnecting and reconnecting the gauge, but no luck. Went onto number 3, got 715 again, then number 5, got 680 this time, then number 7, got 790 this time, lower numbers but by this time the engine had cooled down considerably. Tried number 1 again, this time got 720, so maybe before the gauge was not connected properly, I was pretty sure it was on OK, could it be something else?
Anyway, knowledgeable good people, I've made it a long story, but can anyone shed any light on what might be happening? I really am quite concerned. I feel my engine might blow up anytime.... I can add that although I'm quite new to diesels, I feel my work is good quality, I take forever doing things, I really like to get things done properly. All glow plugs were out, gauge was connected properly, I cranked it until the pressure stopped rising, on average that was 10 seconds cranking per cylinder, some 9, some 12. What in the world is going on.....?
P.S. Jim - thanks again for writing those books. For the next issue, may I suggest an article about how to correctly do a compression check. Such an important procedure and so many things to take into consideration.....
