Duramax 6600 Welcome to the Internet's first Duramax 6600 diesel discussion forum for the LB7, LLY, LBZ, LMM, LML, LGH & L5P RPO code engines. Tips on performance, fuel economy, troubleshooting and more. |
Thread Tools | Display Modes |
Thought I lost #6 injector, replaced all the injectors,cp3 pump and injector lines got it back together and still have a miss. Programmer shows miss fire on #6 .what-do I do now?
I've see a lot of piston failures misdiagnosed as injector failures. Often times you can tell just by the amount or the puffing of blowby. Also tends to have a +15 balance rate.
Kennedy Diesel-owner More than just a salesman-I use and test the products that I sell on a daily basis! Superflow Lie Detector in house 2002 Chev K2500HD D/A CC Long LT 11.77@ 124mph at 7700# fuel only-e.t. needs help 2005 Chev K3500SRW D/A CC Long LT(SOLD) 2007 Chev K2500 Classic EC Short LT (Sold) 2012 GMC K3500SRW D/A CC Long LTZ Happy Birthday to me! Built 1 working day after my birthday and delivered 7 days later. 2016 GMC K3500SRW D/A CC short LTZ Custom tuning in house using EFI Live tuning software! |
Thank you for your advice, I have concluded it is piston failure. What is the easiest way to remove the engine? Remove the cab or remove the radiator and core support? I’ve heard both ways. Any advice is greatly appreciated.
![]() Quote:
What is the history of tuning etc? Pistons don't have a high tendency to fail unless run hard with overly aggressive tuning or abused by a failing injector.
#5
I’ve put almost 100 k on this truck it has190000 on it now. Edge evolution was on the truck when I bought it. I usually run it on the 3Rd or 4th stage. Every thing is stock.
#6
I bought the truck 7 years ago with about 90k on it. It now has 190k,it has an edge evolution programmer, I kind of bounce around between 2-3&4 on it every thing else is stock except air cleaner. I’m usually pulling something fairly heavy with it.
Thread Tools | |
Display Modes | |
