Originally Posted by
Madrugador
Now the engine fires up and everything should be great, but what happens afterwards is that the glow plug light comes on and off intermittently with a series of clicks from the controller showing that the system is doing something.
I'm assuming this stops after a few seconds once the engine is running? If so, this is normal operation and is called "after glow." It's to help the engine smooth out after it is running but still cold. Even on my electronic 6.5L diesel, it will cycle the plugs 2 to 3 times (depending on ambient temperature) for a second or two each time after the engine has started.
If the plugs continue to cycle without stopping, then there is an issue with the glow plug controller.
