Page 4 of 4 FirstFirst 1234
Results 61 to 62 of 62
Thread: Bypass cooling for the 6.2/6.5
  1. #61
    May 2017
    North Carolina
    Default Head Gaskets
    I was reading the article and why would you make the holes in the head gasket so much smaller than the passages in the block and head?
    Also wouldn't make the engine run cooler with increased head gasket passages?
    Wouldn't you drill them out to match the ports in the block and heads?
    1995 Chevy 2500, 6.5L Diesel mostly stock 234,000 miles. Changed the water pump to HO WP, deleted the vacuum pump and added a mechanical wastegate controller made by me with info from others on the forum.
  2. #62
    Quote Originally Posted by gsimpson View Post
    There are a lot of engineering principles involved with coolant flow and heat transfer. The various holes in the head gaskets are sized to allow a prescribed amount of coolant flow. The size of the coolant passages in the head/block are the size they are for at least a couple of different reasons.... 1- Manufacturing ease and core cleanout. 2- To control coolant flow.
    This is why the article was written.... Wannabe vendors just can't decide on their own to change coolant flow without some sort of dynamic testing on a fully instrumented engine to measure the effects of any change. The vendor data should also be published so it can be verified.
