Results 1 to 2 of 2
Thread: chevy 4L80e cummins conversion?
    Feb 2003
    Grand Rapids MN 55744
    Default chevy 4L80e cummins conversion?
    Howdy
    Current 6.5 truck is getting tired and starting to sound loose. Has anyone done a cummins conversion with an automatic transmission? Just feeling out my options....
    Thanks in advance!
    2001 Chinook RV, V10 gas
    1967 GTO, 1989 Honda Transalp
    3 kids, 1 wife, 1 dog
    Sep 2006
    You'll need some type of adapter and electronic controller to get 4L80e to work with the Cummins. I would also recommend a lower stall converter. That said, once you're finished you'll wish you would have done the conversion earlier. Much more power, better fuel economy and simplicity are a few of the advantaged.
    1990 ¾ ton 4x4 Chevy Suburban
    -Gear Vendors Overdrive
    -Upgraded Holset HX-35 turbo
    -NP205 iron transfer case
    -3.73 gears
    1982 ½ ton Chevy Suburban
    -Stans headers
    -Ported heads
    -Timing gear
    -4 speed automatic
    -3.08 gears
    -30 mpg on freeway
