Results 1 to 6 of 6
Thread: Where To Drill For 5th Wheel Trl Plug In Cargo Bed?
    Aug 2008
    Elk Grove, CA.
    Default Where To Drill For 5th Wheel Trl Plug In Cargo Bed?
    I am going to be installing a trailer plug for a fith wheel in the cargo bed. My question is where are you drilling the hole on a 2008 standard size bed? Pictures would be helpful if anyone has them.
    I will be using a new harness that plugs into the bumper harness and them run the plug end thru into the trailer bed.
    Thanks in advance,
    Bill Small
    2020 GMC-3500 Denali
    CrewCab 4x4
    56 Gallon Titan Fuel Tank
    2008 GMC CrewCab
    4x4 6.6L SLT-2 LMM Duramax
    Allison 1000 6 Spd. (SOLD)
    Most common is between the forward edge of the fender, and the front of the bed, about 4-6" above the floor (driver side). I install them rear of the fender, about 6" above the floor and about 4" from the rear ( from the corner where the sheet metal flattens). Much easier access, IMO (you don't have to reach over the bed rail), and you don't have to splice into the middle of the harness if you don't have the camper provision. You can also use a Tee connector (GM or Napa) at the trailer wiring connector (above the spare tire, near the bumper), which is a better option than cutting/splicing.
    Aug 2008
    Elk Grove, CA.
    Thank you very much! I do have the Tee Conector that you mentioned.
    Bill Small
    CrewCab 4x4
    2008 GMC CrewCab
    Geneva, IL
    Hi,
    I confess that the last two fifth wheels I've owned, I just plug into the trailer plug that's already installed below the bumper. The power cord is long enough, it has never bound up or shown signs of wear, and saves me work.
    FWIW.
    Rich Phillips
    Jan 2007
    Somewhere between WI & WY
    Quote Originally Posted by richp View Post
    Hi,
    FWIW.
    Rich Phillips
    That is what I have been doing since I started pulling a 5th wheel. One less electrical connection to corrode.
    08 Blue Granite Silverado LTZ, DMax/Ally, CC/LB/4x4, Cab lights, Camper mirrors, Brake controller, Sunroof, Park assist, and skinny tires
    06 Jetta TDI
    00 Jayco 263RK (2nd home)
    upgraded to an "09" Ranger 619VS/full windsheilds, w/an ETEC 225HO, T8 kicker, Minnkota 101 Terrova, and Lowrance electronics.
    Real Trucks have LONG BEDS!
    Mar 2001
    williamsburg, ohio ,usa
    Quote Originally Posted by Runaway_Dmax View Post
    Less corrosion opportunities and just easier.
    Bob O.
