Originally Posted by
Mark Rinker
Well, the SES light has gone back off, and the truck is still running fine so I have decided to take a wait and see what happens next approach...
Mine did the same thing, but the codes were still out there. BTW, I didn't notice any degradation in truck performance. In my case, I was able to visually inspect my MAF sensor and see that it was faulty...the wire that goes across the front was broken. It takes about 15 minutes to take out the sensor, inspect it, and put it back in. You will need one of those star-type screw drivers...not a torx....on the two screws. While it's out go ahead and give it a good spray with Tuner Degreaser or some other electronics spray cleaner. Good luck.
JP
Jeff
2013 Caprice PPV 6.0L
