Results 1 to 12 of 12
Thread: Where to start? S10 diesel
    Default Where to start? S10 diesel
    My 2000 S10 extended cab (4-cyl.) is creeping up on 200,000 miles. It still runs good, but it's losing power and gas mileage. I would like to convert it to diesel, preferably a turbo diesel for power. I don't tow or haul with it and don't plan to, I just drive a lot on the highway and would like better mileage, or better power without worse than the original 26 MPG. Right now it's worse than 20.
    Where do I start? I'm looking for direct engine replacement only, to stay with a 4-cylinder that will fit under the hood. I'll need to keep the AC - Texas summers are hot. It's an auto trans now, but I'd be willing to change it over to manual if necessary.
    A bolt-in conversion or a site that makes a conversion "kit" would be awesome; a recommendation for a shop in central Texas would be great too.
    Nov 2006
    Kelowna, BC
    Mercedes 5 cylinder diesel would be your best bet. it will fit nicely with lots of room, relatively. as far as i know, if you use the mercedes tranny, the crossmember and the tranny mount will even line up perfectly. good luck with the conversion
    Feb 2010
    St. Marys, GA
    Default Jeep 2.5 5 spd 4x4 convert to diesel
    Afternoon to ya'll,
    I just got on here because I have seen that people are putting diesels in to Jeeps. I was wondering, first, what would be the best possibility for this project, as far as the diesel. I am looking for some power but not heavy, heavy duty. And also, I was wondering what all I would need to do and buy for the conversion. Thanks in advance for the help.
    Quote Originally Posted by 6.5 Detroit Diesel
    That sounds great - I guess the way to go would be to find a used Mercedes with a running engine? Any idea what year and model would work best with a 2000 S10 extended cab?
    May 2005
    SE Wisconsin
    Isuzu 4 cyl would be your best bet. You should be able to find one that bolts up to the GM transmission. They were offered in the S10 from the factory. My second choice would be the VW as there are more adapters available than the Mercedes.
    1997 GMC Savana - 6.5 TD
    1967 Jeepster - Stock
    1986 Jeep CJ7 - Stock
    When I search "mercedes diesel" on eBay I get about 1,000 results, many of which are diesel cars still in running condition. I even found a 1983 280D wagon for $1,000. When I search "isuzu diesel" I get about 300 results, almost all of which are cab-over-chassis trucks. As far as I know, the Isuzu Hombre was never available in the US as a diesel. This makes the Mercedes coversion my only real choice.
    May 2005
    SE Wisconsin
    Quote Originally Posted by CWR032 View Post
    The S10 was offered with a diesel in the US, but they are "rare". You can find more Isuzu Pups with the diesel.
    Quote Originally Posted by HH View Post
    Yeah, I found one on eBay, a 1984. The guy wants not less than $8,750 for it. I've driven one - it has NO power, and they weren't very good either.
    The second generation S10 and the Isuzu Hombre was never sold in the US in a diesel, so a direct replacement like that is out.
    Sep 2006
    In some parts of S. America, a very popular truck there is the Chevy D-Max which often has a 3.0 Diesel in it. It's too bad they don't sell that truck here because it would sell like hot cakes.
    http://en.wikipedia.org/wiki/Isuzu_D-Max
    1990 ¾ ton 4x4 Chevy Suburban
    -Gear Vendors Overdrive
    -Upgraded Holset HX-35 turbo
    -NP205 iron transfer case
    -3.73 gears
    1982 ½ ton Chevy Suburban
    -Stans headers
    -Ported heads
    -Timing gear
    -4 speed automatic
    -3.08 gears
    -30 mpg on freeway
    Jun 2008
    I'm in the same boat.
    I've got a 96 S10, with a blown 2.2, I don't really want to spend the dough to rebuild the 2.2, I'd rather go with a diesel and do a waste veggie oil conversion.
