Results 1 to 7 of 7
Thread: VIN Check help please.
    Sep 2013
    arlington, tx
    Default VIN Check help please.
    Hi,
    I bought a 2006 3/4 2500 LS w/duramax 2 days ago and am trying to decode the options that are on the truck. I figured out the ext cab, long bed. LLY, Allison trans, but all the other stuff???
    My VIN - 1GCHC29236E127704
    Thanks for any help with this.
    walt z.
    Dec 2002
    Teton Valley, Idaho
    googling "GM VIN decoder" yields this as the first result:
    http://service.gm.com/dealerworld/vincards/
    that leads to your ride, a couple of scrolls down this page:
    http://service.gm.com/dealerworld/vi.../vincard06.pdf
    You can take it from there
    Sep 2013
    arlington, tx
    Hi,
    Thanks for the reply. I was hoping that the VIN could be translated to give me what options were installed and what the truck's history is (I've seen this in other "VIN help" posts).
    Thanks again,
    walt z.
    Dec 2002
    Teton Valley, Idaho
    What you need is the RPO decoder. All those 3 digit codes on the sticker on the glovebox door will tell you everything on your truck. Decode it here:
    http://aplsweb.com/Topics/TopicPix/RPO.pdf
    A GM dealer will be able to tell you the history of your truck (what the dealer knows of it anyway) using the VIN.
    Jun 2020
    Old Glory, TX
    Default Vin check help
    Looking at buying a 2014 Duramax with the LML. Would anyone be willing to help with doing a vin check to see what warranty/ mechanical work has been done? Truck has 97000 miles. 1GC1KVC8XEF126027
    Thanks for the help!
    You need to got to a dealer for that info, if the links in this post didn't help you.
    Good Luck
    Jun 2020
    Old Glory, TX
    Okay, will do, thanks for the reply.
