Thread: 6.2 ran out of fuel now won't start
    May 2020
    Fairbanks Alaska
    Default 6.2 ran out of fuel now won't start
    Hello, new to forum and to 6.2s I have an 86 k20 with the 6.2 and I ran out of fuel got it towed to fuel station and put diesel in it. I bled off the fuel system and got it running. Went to work the next day and it died at a stop light and wouldn't start again. Got it towed home and have had no luck since I have bled the fuel system even installed a clear hose off the injection pump like I seen recommended in here. And I am still having no luck and have no idea what may be causing it to not start. Any help is appreciated.
    Plug it in,put a battery charger on the batteries,remover the glow plugs,test them,check your electric fuel shut off solenoid,crank it till you see fuel mist coming from the glow plug holes.
    If the glow plugs are good,and you get fuel misting from the holes,replace the glows and give it a try.
    May 2020
    Fairbanks Alaska
    Glow plugs are new, and I can here the solenoid click when I put power to it. Still havent had any luck. I will try removing them and seeing if I am getting anything.
    New plugs have been known to fail.
    What kind of glows,and did you test the system to make sure they are getting power?
  1. Will running out of fuel damage a DS4?
    By arveetek in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-24-2012, 21:47
  2. 82-83 6.2 should start in well under 3 seconds
    By 4boltmainiac in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 04-10-2011, 00:54
  3. No start 6.2
    By Kcustom73 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 04-09-2011, 14:00
  4. Westers Garage OBD2 Programming Software
    By ECMProgrammer in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 05-05-2007, 09:13
  5. Won't start, No Fuel, ignition switch? ECM?
    By Hubert in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 10-24-2004, 16:39
