Thread: Flat bed install
    Dec 2005
    Klamath falls/keno Oregon
    Default Flat bed install
    Has anyone put a flat bed on their truck ?
    I’m trading a guy my old S-10 PU for a flat bed, it came on
    an older ford and the frame rails Are wider.
    I’m thinking of either moving the rails inward or adding two new rails
    Thoughts
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    If it's an engineered manufacture brand, as most major brands are, I suggest adapting to retain strength (both left unmodified). If it's home-built or low end, it may not matter, or may be useless if you change the structure.
    Dec 2005
    Looks like a Bradford Built.. Do u think there’s a cartoon of the Bed bolt pattern of my truck somewhere ? I would like to draw out another cartoon of what it should look like before jumping into the project..the kid that has the flat bed says he’s a fabricator and his dad has a machine shop..
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    I don't know about the cartoons, but I'm sure someone has measured, and perhaps took some pics. The bolts/nuts are easily accessed from underneath, so you may not need all that. I think your biggest challenge is going to be adapting the ridiculously stupid Ford taillight wiring to the slightly less ridiculously stupid GM chassis wiring. The fuel filler pipes may also be an issue. Or maybe not. I just don't know.
    Dec 2005
    yeah that too...I’ve had the bed almost off when I installed Kennedy’s dual lift pump.
    Hummer wheels :^)
    dual lift pump
    Banks air intake
  1. Flat bed conversion?
    By gimpyhauler in forum 2500HD/3500 Accessories
    Last Post: 10-13-2016, 18:37
  2. FS: DFW, Texas - 1988 GMC 6.2 Diesel 1 Ton Flat Bed Dually
    By smithworld in forum TDP Classified ad forum
    Last Post: 01-29-2012, 15:27
  3. B&W turnover install on 98 short bed
    By JoeyD in forum Towing - 5th-Wheels & Travel-Trailers
    Last Post: 05-13-2005, 16:50
