Thread: 6.5 turbo starting issues
    Dec 2019
    Shelby n.c
    Default 6.5 turbo starting issues
    I have a 1984 c30 I done a 6.5 Td swap on new starter and new batteries I can turn engine over with breaker bar no issues but when I attempt to crank it drags very slowly I’ve checked all my connections the only thing I haven’t checked is the starter between engine block to make sure it’s clean any advice would be greatly appreciated
    Knoxville,Tennessee
    Is the nose brace on the starter?
    -Patrick Henry
    A5150nut
    2006 K3500 D/A
    94 6.5 4x4 5spd Sold
    Jan 2005
    Denville,New Jersey
    Mine did that about 5 years ago. Using an AC Delco Starter solved it.
    Feb 2003
    Grand Rapids MN 55744
    Howdy
    The starter should be clean between the block.
    NEW bolts used and torqued to spec.
    Make sure the nose bracket is in place and TIGHT.
    Check ALL your cables. IMHO....If they are old at all, Replace with heavy gauge welding cable and industrial electrical grade crimp ends.
    Battery and ground connections need to be checked.
    The quality of the starter can also be a problem, NEW AC Delco is what I have the best luck with. expensive....but they work.
    Hope this helps!
    2001 Chinook RV, V10 gas
    1967 GTO, 1989 Honda Transalp
    3 kids, 1 wife, 1 dog
  1. 6.5 Turbo Diesels Kit for 6.2 Square Body
    By 83Blzr62 in forum TDP Classified ad forum
    Last Post: 06-17-2020, 13:28
  2. 6.2 liter injector pump on a 1996 6.5 turbo diesel
    By Duelly79 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 09-28-2014, 15:05
  3. 6.5 turbo setup in pre 88 body style trucks
    By Vin82k3500 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-07-2013, 18:44
  4. Hard starts, no starts 6.5 turbo diesel
    By UtahMurph in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 04-17-2012, 14:14
  5. 6.5 Turbo manifold for sale
    By 84 Convert in forum TDP Classified ad forum
    Last Post: 03-29-2005, 20:50
