Results 1 to 6 of 6
Thread: Service air bag notice..
    Dec 2005
    Klamath falls/keno Oregon
    Default Service air bag notice..
    What’s up with this?? It’s in my dash..
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Usually a poor connection, somewhere, but check the fuses first. If it isn't that simple, pull the BCM codes and it will tell you which circuit. If you driven off road (or on a really bad road), debris can dislodge a sensor on the frame. They're fairly well protected, but I've pulled twigs and rocks from stranger places. All the SRS connectors and components are yellow, or significantly yellow.
    Owego, NY
    Several years ago, I was getting the "Service Air Bag" message and the steering wheel control buttons for the Radio also weren't working. Replacing the steering wheel "Clock Spring" wire harness resolved the issue. My understanding is that SIR (Sudden Impact Restraint) system diagnostic checks connections to the Air Bags one of which is in the steering wheel.
    Bill
    98 K3500 6.5,SOLD
    Dec 2002
    Teton Valley, Idaho
    Spongebob, did you find a resolution to the issue? Oddly enough, my DIC started telling me to service airbag system last week...
    Dec 2005
    I cleared the code, and never got around to finding out which sensor it was..code hasn’t resurfaced.....yet
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Dec 2002
    Teton Valley, Idaho
    I pulled the code that pointed me to a front sensor error. Cleared it and it came right back. Removing the sensor (pull the splash guard and it is mounted on the bottom of the radiator) showed plenty of corrosion in the mounting hole, so I replaced the sensor ($150 for the Dorman version, $250 for the GM). Plugged it in, good to go.
  1. Another flavor of air in fuel problem
    By ulhpilot in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 11-30-2017, 20:02
  2. Air Bag Light On ??
    By Davis in forum 1982-2000 C/K Truck & SUV Chassis & Drivetrain
    Last Post: 02-15-2007, 13:18
  3. air conditioning service ??
    By PHAEG in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-19-2005, 04:22
  4. Air bag rear suspension
    By Herman_Bolger in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-27-2005, 09:10
  5. My truck flows more air than your truck
    By gmctd in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-10-2004, 18:22
