Results 1 to 6 of 6
Thread: Glow plugs again
    Dec 2009
    In the North
    Default Glow plugs again
    Now the burb is starting fine(sort of) its time to get all 8 to fire cold,. So i'm looking to buy some plugs,.
    Is there a latest and greatest new thing to come along?
    Lots of low priced glow plugs on amazon,. Has anybody been using them?
    Just curious for any real life testing going on,..
    1999 chev suburban C2500
    300,000 mi
    AC DELCO 60G
    Stay away from the goody goody crap.
    The 60G plug takes a tad more time to glow, but they don't swell up when they go away.
    Remember.
    You can access all but number 8 on the RH side through the access hole in the inner fender..
    I added a mouse hole in the Dahooooley which allowed accessing the #8 plug and the heater hoses too
    Remove the tire/wheel and then the rubber flap
    PIX https://www.thedieselpageforums.com/...ING+GLOW+PLUGS
    I have Kennedy's Quick Heats in my rig:
    http://www.kennedydiesel.com/categor...SubCategory=61
    Dec 2009
    In the North
    AC DELCO 60G
    Remember.
    Thanks Robin,. My luck probably is #8
    300,000 mi
    Unless #8 is very cooperative....leave it alone..
    Having 7 plugs working will get the six and a half lit up fine.
    #8 will come up in a few seconds anyway.
    A bit of extra smoke will handle the Skeeters
    Dec 2009
    In the North
    Haha!!
    My thoughts exactly!!
    300,000 mi
  1. 1993 6.5 turbo glow plugs and injectors
    By jjmoore in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-19-2012, 15:40
  2. No glow plugs, cranks, but no start
    By jf-schaack in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-10-2011, 06:24
  3. Glow Plugs
    By MEP in forum Duramax 6600
    Last Post: 10-28-2008, 19:29
  4. GMC 6.2 Glow Plugs & Controller (1988) Questions
    By mchitko in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 10-16-2007, 17:10
