Thread: 6.5 starts, exhaust comes out from turbo area then stalls
    Feb 2020
    thompson ct
    Default 6.5 starts, exhaust comes out from turbo area then stalls
    1997 Gmc 6.5 turbo diesel, little over 98,0000 miles. I replaced lift pump, new injector pump and pmd, moved it to firewall area with kit but is still grounded to pump. I replaced water pump and timing chain. am getting fuel out of screw top fuel filter, out of T handle, I did remove all glow plugs and tested, they are good, was getting mist spray from gp holes. baterries are 3 months old, starter and motor are turning overy plenty. Turn key to on position, let glow plugs cycle then turn over, motor will fire for couple seconds then stall. I get alot of exhaust comming from turbo before it stalls out, cant figure out why it will not stay running. no noticible air leaks/fuel
    Quote Originally Posted by thompson View Post
    I replaced ... timing chain
    Did it run before you did this?
    What do you mean by " I get alot of exhaust comming from turbo"? does it not have an exhaust system, or are you saying there's a big leak?
    Has it got a catalytic converter?
    If it does remove the exhaust from it and try again.
    I got a free 99 Suburban that the PO did everything to to try and get it to run longer than a couple of seconds.He spent the better part of a week working on it outdoors before he walked away from it.Not that he was the brightest bulb in the set.
    Sat in my yard for a few years befor i got it for being abandoned.I pulled it in the shop ,returned everything back to stock.It would start and die almost immediately.Up on the hoist and split the exhaust by the converter,fired up and stayed running.
    The converter was plugged soild.I removed it from the exhaust and it runs great.I got about 2-3 gal of black soot from the exhust once it fired without any restrictions.
  1. 6.5 Turbo Diesels Kit for 6.2 Square Body
    By 83Blzr62 in forum TDP Classified ad forum
    Last Post: 06-17-2020, 13:28
  2. 6.5 non turbo to 6.5 turbo questions
    By gattlin in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 09-24-2016, 14:35
  3. Will a factory 6.5 turbo system work on an 80's 6.2?
    By More Power in forum 6.2L/6.5L Diesel - Upgrades & Service Questions Answered
    Last Post: 11-12-2013, 12:10
  4. 6.5 exhaust on Banks 6.2 Turbo
    By flomulgator in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-22-2011, 12:24
  5. Repower for driverless HMMWV?
    By Red Whittaker in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 11-30-2003, 07:44
