Results 1 to 20 of 36
Thread: Please help!! 6.5 Td 4l80e issue
    Nov 2019
    USA Florida crestview
    Default Please help!! 6.5 Td 4l80e issue
    Hey guys,
    I got my 1993 Chevrolet k2500 Silverado with 6.5l td a couple months back, and it had a bad and leaking transmission (4l80e).
    Installed a remanufactured one the day before yesterday and at first when I started it, and put it in drive, the engine would stall.
    After that cleared up and the truck run, i had erratic shifting through first and second gear. I could shift it manually and it would work fine. Went to drive it today as b.d it won't come out of 2nd gear no matter what I do. Changed tcm, and both speed sensors and no change.
    I did a diagnostic scan a little while ago, and this is what I got...
    22,39,59,18,38,58,68,78
    DTC 18 - Pump Cam Reference Pulse Error
    DTC 22 - Accelerator Pedal Position 1 Circuit Low
    DTC 38 - TCC Brake Switch Stuck "OFF"
    DTC 39 - TCC Stuck "OFF"
    DTC 58 - Transmission Fluid Temp Circuit Low
    DTC 59 - Transmission Fluid Temp Circuit High
    DTC 68 - Transmission Component Slipping
    DTC 78 -Turbo Wastegate Solenoid Fault
    Can anyone tell me which of these would cause my issues?
    Nov 2019
    I almost forgot, my speedometer is off. Not by any specific mph, at 35 you're going about 33, and at 85 you're going 75
    Multiple seemingly unrelated codes are often caused by power issues.
    First, check all your battery and ground connections. Check the battery leads for corrosion at the connectors under the insulation.
    If that doesn't do it, there should be a fuse labeled "instruments". Check the voltage at that fuse. It is fed by a separate set of contacts in the ignition switch and they are problematic. Among other things, it controls the transmission and the speedometer. Also check the voltage on the main circuit coming out of the ignition switch.
    Clear all the codes and see which ones come back.
    Wait a minute. Am I getting senile, or should a '93 not have an APP, pump cam or waste gate solenoid? All that stuff came out in 1994. Do you have a mechanical injection pump or an electronic one? Put more basically, does your throttle operate by a cable?
    Yes...
    All that electronics on a 93 ?????
    Maybe a really early 94 sold as a 93 ?? or the paperwork got messed up.
    First thing.
    As mentioned....Make sure the power to the main panel is reading 13.5-14.5 V while the engine is running.
    Make sure voltage at both batteries is reading the same.
    Positive cables
    Negative cables
    Chassis to engine ground
    Body to chassis ground
    Clear all those codes and then fire up and see what comes back.
    Old codes stored in memory can come out and haunt you.
    Very well could be the stored codes are causing a LIMP MODE issue
    Nov 2002
    Martinsville, IN
    What's the VIN?
    A 93 should have no DTCs associated with engine functions at all.
    Nov 2019
    Ok, after a fun filled day under there hood, I finally traced everything down and got all the codes clear. No more ses light.
    It is a mechanical ip. Vin number is 1GCGK24F8PE219191.
    It's finally out of limp mode, but I'm still getting a problem in first and second gear, like it's going in and out of gear. I can manually shift it from first on up and it doesn't do it. Also it does the same thing going back into first on the down shift.
    They're sending me a new transmission tomorrow, but I'm worried I'll have the same issue.
    Nov 2019
    I'm honestly about ready to put a standard trans in it and call it a day
    Your VIN decodes to a 1993. 1993 should have a mechanical injsction pump, as you say it does. The codes DTC 18 - Pump Cam Reference Pulse Error, DTC 22 - Accelerator Pedal Position 1 Circuit Low, and DTC 78 -Turbo Wastegate Solenoid Fault can only be generated by a 1994 or later PCM. I'm not surprised your trans doesn't work right. You need a '93 TCM (Transmission control module) or, I understand there are aftermarket TCMs available that work, also. Also, if you look into folks that have done mechanical pump conversions on later trucks you might find a workaround, although I recall the solution was a TCM.
    Somebody installed a later control module ?????
    Before I swapped out the tranny I would see about scaring up the correct module.
    No way can the ECM from a 93 send out the codes pertaining to a 94 or 95 electronic setup...
    Nov 2019
    Just put a new tcm in, same problem with trans. Ses light still isn't on, but it still surges through first and second.
    I didn't have these problems with the transmissions I took out.
    Quote Originally Posted by Bigrig594 View Post
    It sounds like you got the wrong or bad transmission. Walk back all the changes you made that either didn't help, or made things worse. You have another transmission on the way, and you won't be able to fix anything until you have the correct or good transmission to work with. These powertrains are generally extremely reliable and trouble-free. Either there is a physical/mechanical or an electronic/communication failure. Start back with your original problem and work forward. While a manual transmission conversion may be desirable for many reasons, this isn't one of them. A conversion will involve many times more headache than getting this right.
    Look at your accelerator pedal. Does it have a round cylindrical gizmo with wires attached? This is the accelerator pedal position sender for a '94 and up electronic pump. If your PCM is generating an APP code then it needs this sensor to get throttle position information. You would also need the mechanical throttle cable from the '93 to operate the mechanical pump.
    Does your wastegate have a vacuum actuated wastegate controller? '93 had a "spring in a can. '94 and later have vacuum actuated, computer controlled wastegates. the DTC 78 is generated by this system, which you should not have in the '93.
    Until you know where you are, it's hard to plot a course to where you want to be.
    Nov 2002
    Martinsville, IN
    I suspect that the "TCM" is actually a "PCM" for a 1994 or 1995 truck...
    Right, with no throttle position input. Not sure how you could expect it to shift the trans properly if it thinks the injection pump and throttle are both FUBAR.
    RJ- were you one of the guys who did a writeup on converting to a manual pump?
    Nov 2002
    Martinsville, IN
    No. I'm not a fan of those conversions. I think Bobbie Martin wrote that up.
    Quote Originally Posted by ronniejoe View Post
    Yes, now that you mention it. That's who I was thinking of.
    Nov 2019
    The accelerator pedal had a cable. No electronics. I do have a tps tho.
    I do have a new tcm for this trick tho as of this morning. I'm no longer getting those codes. Now I'm getting 58,59, 81 and 85.
    The wastegate doesn't have any vacuum lines or the like going to it. As far as I can tell everything matches up with the year model of the truck aside from the trans.
    I think I just got a bad trans, it is a remanufactured one after all. The new one should be here today sometime. I'll install it over the weekend and see what I got from there.
    Those are all trans codes, so you're on the right track. Did you have a PCM from a 94-95 truck in there before? I don't see how that could ever work!
    Nov 2019
    The numbers matched up for the one the parts house looked up. So, I'm assuming it was the right tcm, I may have just looked up the wrong code chart or something. I'm working with a paperclip and Google after all lol.
    Just went and got the new transmission, I'll install it Sunday and see what I have after that.
    Might my vss on the tcase cause the shift issue and speedo issue? That's the only sensor I haven't changed out yet.
    I'm only curious at this point. I'm still gonna put the new one in regardless. There's no telling what may have gotten damaged with all my troubleshooting and what not.
  1. Researching 4L80E to NV4500 Transmission Swap
    By trbankii in forum 1982-2000 C/K Truck & SUV Chassis & Drivetrain
    Last Post: 08-10-2016, 10:02
  2. FS: Misc 6.2 & 6.5 Parts -Montana
    By AsphaltCowboy in forum TDP Classified ad forum
    Last Post: 08-04-2015, 00:08
  3. Some 6.5 diesel "Gum shoe"
    By Robyn in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-29-2011, 07:17
  4. 1995 C3500 2wd 6.5 Clutch Issue
    By clem_acc in forum 1982-2000 C/K Truck & SUV Chassis & Drivetrain
    Last Post: 02-06-2008, 19:46
  5. Best Diesel Shop in Salt Lake City to diagonose Timing issue on 6.5?
    By Mitch-SLC in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-04-2005, 07:03
