TheDieselPage.com Forums
The Diesel Page Forums
2020 - TDP's 24th Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Forums > 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance 1992-00 6.5L Turbo Diesel - Welcome to the Internet's first discussion forum for the 6.5L diesel engine. Tips on performance, upgrades, cooling, fuel economy, troubleshooting and more.
Reply
Thread Tools Display Modes
  #1
Old 09-18-2019, 09:45 AM
1996-6.5 1996-6.5 is offline
Newbie
Default RPM Jumps from 1200 to 2000
the rpm of my 6.5 Jumps from 1200 to 2000 no matter how much i try to feather it.I replaced the accelerator pedal and the fuel pump. took it to the local diesel experts. they told me it came that way when sold new??*Ideas Thoughts??
  #2
Old 09-18-2019, 10:00 AM
JohnC's Avatar
JohnC JohnC is offline
Proud Deplorable
In neutral? Maybe not an issue.
I've seen "twitchy" throttles caused by the wrong (to high) resistor in the PMD, but, if you have a new pump that shouldn't be a problem. If it is rebuilt, it depends...
Is your lift pump healthy?
__________________
"Need" - Wanting to get someone else's money.
"Greed" (formerly meant what "need" means today) - wanting to keep your own.
"Compassion" - a politician's willingness to arrange the transfer.
-Joseph Sobran
Current oil burners: MB 350SDL, Kubota 7510
Gone but not forgotten: '87 F350 7.3, '93 C2500 6.5, '95 K2500 6.5, '06 K2500HD 6.6
  #3
Old 09-18-2019, 10:03 AM
Robyn's Avatar
Robyn Robyn is online now
Missy Good Wench ( Moderator)
The 6.5 should NOT jump RPM that much.
You should be able to gradually raise the RPM from idle right on up to a very high RPM without the drastic jump.
Internal injection pump issues most likely to blame.
I would say that the fuel solenoid is getting worn and it is not responding properly.
__________________
(1) 2007 Chevy Avalanche
  #4
Old 09-18-2019, 05:19 PM
Newbie
Default repairing the flat spot...
I replaced the lift pump and PDM last year from leroy. thinking that would take care of it. sadly no.*I just spoke to my mechanic*about replacing the fuel solenoid. He tells me we should replace the injection pump at the same time to be on the safe side as it is the original.*thanks for the ideas of how to take care of the headache.
I will post on the outcome when finished.
Thanks again
  #5
Old 09-18-2019, 05:38 PM
DmaxMaverick's Avatar
Administrator
If it is original, 23 years of IP service doesn't leave much to complain about, really. If you aren't seeing a STS (Service Throttle Soon) lamp/code, I agree with the suspect IP.
__________________
  #6
Old 09-18-2019, 06:15 PM
JohnC's Avatar
Proud Deplorable
OK, I thought you meant the injection pump when you said "fuel pump". Yes, definitely, if it is original, it's a miracle it still runs!
When you replaced the PMD, what did you do for a resistor?
__________________
-Joseph Sobran
  #7
Old 09-19-2019, 04:39 AM
Robyn's Avatar
The fuel solenoid I referred to is not the shut off up on top, but instead the actual fuel control inside the INJECTION PUMP.
This part is not normally a local shop replaceable item..
A properly rebuilt injection pump that has been tested on a stanadyne test bench is the best route to go.
Good luck
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
