Thread: Instrument panel cluster pinout
    Feb 2012
    Pauline, SC
    Default Instrument panel cluster pinout
    I'm looking for a diagram that shows the cluster pinout information. Everything I have found on line wants a credit card ...
    I have a Dakota digital dash for my 93, I need the info for the pin outs located behind the dash for the cluster, the plug the cluster plugs into.
    If anyone knows where I can get a schematic let me know.
    1993 Chevy K3500
    like us on Facebook
    Hey
    I dug out my 1992 GM factory schematic.
    These pics are for the diesel dash
    Hope these will help.
    The 92 dash should be the same as the 93
    The one piccy gives the wire number and color...the other is the dash itself that will let you trace where the wire goes.
    Feb 2012
    Pauline, SC
    Many thanks, now to figure out how to read it...
    1993 Chevy K3500
    like us on Facebook
    Remove your dash from the truck.
    Look at the plug
    Take note of the colors on the wires.
    Use colors to relate to the wire numbers
    Trace each line from the numbered pin on the schematic to where it goes in the cluster.
    The Dots where circuits cross is a junction.. if there is no dot where lines cross it is not a connection.
    Follow the traces.
    The pink and black wires (#39) are 12Volt power that's hot when ign in start or run position..
