Results 1 to 7 of 7
Thread: RPM Jumps from 1200 to 2000
    Sep 2019
    Cheshire Oregon
    Default RPM Jumps from 1200 to 2000
    the rpm of my 6.5 Jumps from 1200 to 2000 no matter how much i try to feather it.I replaced the accelerator pedal and the fuel pump. took it to the local diesel experts. they told me it came that way when sold new??*Ideas Thoughts??
    In neutral? Maybe not an issue.
    I've seen "twitchy" throttles caused by the wrong (to high) resistor in the PMD, but, if you have a new pump that shouldn't be a problem. If it is rebuilt, it depends...
    Is your lift pump healthy?
    The 6.5 should NOT jump RPM that much.
    You should be able to gradually raise the RPM from idle right on up to a very high RPM without the drastic jump.
    Internal injection pump issues most likely to blame.
    I would say that the fuel solenoid is getting worn and it is not responding properly.
    Sep 2019
    Cheshire Oregon
    Default repairing the flat spot...
    I replaced the lift pump and PDM last year from leroy. thinking that would take care of it. sadly no.*I just spoke to my mechanic*about replacing the fuel solenoid. He tells me we should replace the injection pump at the same time to be on the safe side as it is the original.*thanks for the ideas of how to take care of the headache.
    I will post on the outcome when finished.
    Thanks again
    If it is original, 23 years of IP service doesn't leave much to complain about, really. If you aren't seeing a STS (Service Throttle Soon) lamp/code, I agree with the suspect IP.
    OK, I thought you meant the injection pump when you said "fuel pump". Yes, definitely, if it is original, it's a miracle it still runs!
    When you replaced the PMD, what did you do for a resistor?
    The fuel solenoid I referred to is not the shut off up on top, but instead the actual fuel control inside the INJECTION PUMP.
    This part is not normally a local shop replaceable item..
    A properly rebuilt injection pump that has been tested on a stanadyne test bench is the best route to go.
    Good luck
