Results 1 to 2 of 2
Thread: Fuel in oil
    Dec 2019
    Montrose Co
    Default Fuel in oil
    Ok to start bought the truck after 6 years of sitting. What I know from previous owner..white smoke at idle..she had both heads replaced due to a cracked head. Injectors and return lines were also replaced at this time. I cleaned fuel system with diesel purge and replaced fuel filter. I replaced pmd due to self acceleration..almost crashed lol..has lots of white smoke at idle. Checked coolant levels and all good there...check oil levels and it will build 4qts in less then 100mi..smells horribly of diesel...paper towel test shows definitely has diesel...no external fuel leaks...no codes...can injectors cause this much fuel in oil?...what other cause could there be for this much diesel in the oil? Thanks in advance for any help provided. Also when it does warm up it will not crank or start untill it cools back down under 160.
    1996 K2500 6.5l TD 5Spd
    Hi
    Welcome to TDP
    Injection pump is likely toast
    Fuel leaking out the front of the pump and into the crankcase.
  1. Water in Diesel fuel
    By mwool in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 08-06-2012, 16:46
  2. 6% fuel in oil - scared for my injectors
    By npauli in forum Duramax 6600
    Last Post: 05-21-2010, 19:40
  3. How big does the oil cooler really need to be?
    By JeepSJ in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-05-2005, 15:12
  4. Code P0202
    By JimErickson in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 10-30-2002, 21:18
  5. Bad fuel - watch out! (long)
    By Steve StLaurent in forum General Diesel
    Last Post: 06-29-2001, 20:35
