Originally Posted by
WhiteMax
Not that I think your wrong but can you show me where you get these temp numbers at? 1365 continous? Sounds great. I have bounced off 1500 in mine. It had me worried.
If your all stock I would not worry about it , EGT probes are not all that accurate . As long as you have over 20lbs of boost when you see high egt and your running stock fueling and nothing blocking air flow to the intercooler I would say your probe is the issue. The 1400* max number was on garrets web site in a specs article when the LLY was in preproduction back in 2004. Who knows if the info is still on there site.
