Results 1 to 13 of 13
Thread: 8-Bolt rims: Ford/Chevy interchangeable?
    Jun 2006
    Surrey, BC
    Default 8-Bolt rims: Ford/Chevy interchangeable?
    Title says it all....I have a line on some factory Ford 1t 8-bolt alloys cheap and my stock steel wheel are starting to rust out. I also need new rubber very soon and I don't really want to put new skins on rusty wheels.
    Will a Ford 8-bolt fir on my Chev? Thanks all. Cheers
    Brett
    2005 GMC Sierra SLT Dually Crew, 4x4, stock
    71,000 kms
    Used to be you could put furd on Chevy but not Chevy on furd. Centers were a slightly larger opening on the furds. Make sure they are 8 bolt. IIRC, furd had some 7 bolts for a while.
    Apr 2005
    Toronto, Ontario
    Ford change their bolt pattern 02 or was it 03 and up...they went to metric 8 bolt after that...
    I used that name because its my username on all my other forums...
    1994 Chevy Sub Diesel K2500
    Jun 2006
    Surrey, BC
    Thanks for the clues guys. I figured it must be too good to be true.
    71,000 kms
    Sep 2007
    Jax Florida
    As long as the ford rims are pre-03 they should work.
    93 GMC Sierra 2500
    6.5L TD Auto
    Aug 2006
    I thought it was when Ford went to the new body style in 1999 they change to the metric bolt pattern.
    Oct 2006
    Lexington, KY
    Quote Originally Posted by 1999GMC View Post
    Bingo, he's correct.
    1997 and earlier Fords used the same 8 lug pattern as GM and Dodge. '99 and up (there was no '98) will have the metric pattern referenced earlier.
    -89 K5 Blazer. "The Blazer." 6.2L diesel, 33's, Rhino Lining, and stock(ish). Tow rig, play toy, and general fun.
    Mar 2001
    Mission B.C. Canada
    Talking
    Clear as mud:
    The 1993 ford rims I have will fit my 1993 Chev front and back
    The 1993 chev rims I have will fit my 2001 chev front and back
    The 1993 ford rims I have will fit my 2001 chev back but NOT the front they hit the calipers.
    As mentioned in previous post the new furd rims dont fit anything but new furds.
    Original D.P. Member #750, 2009 Ext Cab LB 4x4 Duramax/Allison, Black, Linex, 1993 6.5 TD 4x4 reg cab LB, 5 speed, 1972 Pontiac Lemans, 94 cady De Ville
    Apr 2000
    Havre De Grace, Maryland
    I also thought 99 was the change to metric for Ford. Pre-99 Ford should be 8 on 6.5 just like GM & Dodge.
    04 Chevy 2500HD 4X4 LLY DMAX LS CCSB
    00 Dodge 2500 4x4 CTD
    86 K5 Blazer 4X4 NA 6.2 aka CUCV M1009
    57 Chevy 210 1ST CAR
    88 Jeep YJ 3/4 axles & SBC
    Mark
    Quote Originally Posted by Turbo Al View Post
    So, are GM 8-lug rims pretty much interchangeable throughout the years? I have a line on some nice 2001 rims that I'd like to consider for my '93.
    Oct 2006
    Lexington, KY
    Sorta. They pretty much stayed with very similar sizes and backspacing from the 80's on. 16x6.5 going up to 16x7 and backspacing was in the 4.25-5" range the whole time.
    The 2001 rims should work fine on your '93. I've actually got some 2007 steel wheels from a GMC on my '86 and have a set of the newer style aluminum wheels that will eventually be on it.
    IIRC, yes. The only difference was Chevy to Ford because ford was about 1/8 in larger diameter on the center (large ) hole.
    Oct 2006
    Lexington, KY
    When Ford went to the current Super Duty design for the 1999 model year they changed their lug pattern a bit.
    For the record I know that just about any pre-1999 Ford 8 lug wheel will work on a GM 8 lug truck into the 90's. Not sure on more modern GM's though.
