Check with the kit manufacturer. Every lifted vehicle I'd had (I've had seven) required different numbers when accomplishing an alignment than it did stock. Especially IFS fronts like yours and my current vehicle.
Drove me nuts with my Jeeps as I didn't realize how different it was, and every time I took them in, I had death wobble so bad I couldn't drive above 30 unless I floored it to 50. Learned after a time or two to take the numbers to them and when it wobbled on test drive, punch them for not using my numbers. I had arguments with many alignment specialists, some think then know everything. One guy wanted me to spend over $800 in new suspension parts, most of which were less than a month old, but in his mind they weren't compatible with my vehicle.
If you can, find a shop that specializes in lifted vehicles, like a "4 Wheel Parts" store or similar. They usually do a decent job.
