What is a P1093?
My SES light has been on for about the last six years and I've come to live with it. The EDGE chip causes multiple codes such as:
P 0106, P 0107, P 0341, P 0380, P 0489, P 2141, P 2144 and P 1093.
I can disconnect the EDGE and soon all code go away. But lately (last several months) the 1093 will come on as soon as I hook up to a trailer. It will go away after I disconnect and stay off till I hooked up again. (no EDGE chip).
I change fuel filters often, refuel at the big truck stops, use PS additive and even changed the entire fuel line from the tank to the filter head. This was done because of a "crimp" in the line at the firewall. By the way, the new line was shipped from GM in a box that was too small and the new line was bent over and crimped in the same spot.
The fuel mileage isn't bad, 11 towing, 16 empty, and the performance is great. The onset of the 1093 code will happen at the lower RPMs when I am going from....say 3rd to 4th or 4th to 5th, etc. After entry to the higher gear and the RPM is low. Am I starving my engine of fuel?
Mike
'02, 315,000 miles, ZF6 and all stock except for the EDGE.
2002 GMC, Pretty Dark Blue, 4x4 / 3500, ZF6, 115 gal spare tank and Rockets... (My Other One): Flying Fuel. I got three engines and a 52,000 gallon tank, how many you got?
